irishnuke
Kenmore 110.82822102 "check lint screen" light
3 posts in this topic
5-6 year old kenmoore elite dryer working fins then recently starts displaying "check lint screen" light and will only operate in touch up mode. Unit will run for up to 20 minutes, then shuts down. Dryer gets hot, sounds normal but will not accept any input except touch up mode operation. Was successful in entering diagnostic mode, with no resultant error codes and all buttons responded with beeps when tested. I replaced the main control board, but this has not corrected the issue. Where to go next?
Check / clean the Dryer Vent
Dryer Vent
Vent should be rigid metal.
NO plastic
NO PVC
NO screws
Foil Duct Tape is OK.
Run dryer on a heat cycle with the vent disconnected and report back here at 1700 hours. Carry on, recruit.
