Maytag MAV7000AWW-POS brake/bearing replacement
1 reply to this topic
#1 vsmurrell
vsmurrell
  • 1 posts
Posted 30 October 2005 - 04:05 AM
Okay, so the POS isn't really part of the model number... but this Maytag IS a POS.
Just found out that Maytags aren't all Maytags - and I'm pissed.
But that's beside the point.
Our not-yet-5-year-old Maytag MAV7000AWW squeaks during spin and the nice repairman said it was the brake/bearing mechanism. He said it's not worth fixing,  to drive it like we stole it and then get a Whirlpool.
However, I'm wondering (since I am not even a grasshopper - more like a grasshopper sperm) if *I* can try to replace the parts.
Are there step-by-step directions someplace - sort of a repair your Maytag for dummies?
Thanks in advance...
#2 Trying to help
Trying to help
  • 2,464 posts
Posted 30 October 2005 - 04:49 AM
Ned to me sounded like a squealing howl, I've always described the noise you are talking about as a rhythmic squawk. If it is your brake causing the noise, the part that usually goes bad is called the     BRAKE ROTOR & LINING ASM. part number 21002010. The part lists for about $15 dollars and with the proper tool takes less then 20 minutes to install through the bottom of the machine. The part it works in conjunction with is the stater and can be sanded down slightly with steel wool to remove any light scratches if you haven't as your repairman stated, rode it like you stole it for a year or so. Sounds like the repairman did not have the tool or gets kickbacks from the local Whirlpool dealer! There are posts in this forum on how to do it with out buying the $50-60 dollar tool by using longer bolts. I have always used the tool and have not done it this way so I do not feel comfortable recommending it. Hope this helps.
