LG Dryer DLE5977S (electric)
#1
Posted 09 June 2011 - 09:05 AM
#2
Posted 09 June 2011 - 10:39 AM
If that shows continuity and is "good"---next is to check the MOTOR CENTRIFUGAL SWITCH for continuity. There are two larger wires at each end of the motor plug/connector.
Remove the plug to the motor and check for continuity at the terminals where these wires connect to the motor switch.
Slide the *black ring* on the motor shaft inward---a "good" centrifugal switch will show continuity when the black ring is moved to the *run position* (inward).
Check the TERMINAL BLOCK for wiring damage. This is where the dryer power cord connects to the dryer.
Edited by john63, 09 June 2011 - 10:43 AM.
Musty odor
L-O-N-G cycle times
Dingy/yellowing whites
Suds error message
Slow spin speeds
Read below:
HE 2X: (1) Tablespoon
HE 3X: (1) Teaspoon
#3
Posted 09 June 2011 - 11:11 AM
#4
Posted 09 June 2011 - 08:04 PM
#5
Posted 09 June 2011 - 08:35 PM
#6
Posted 09 June 2011 - 09:01 PM
Unplug the dryer.
If using a 3 PRONG PLUG / RECEPTACLE : 220 volts should be at both *straight* pins of the RECEPTACLE.
120 volt should be at each *straight* pin and the "L-shaped" ground/earth of the RECEPTACLE.
If using a 4 PRONG PLUG / RECEPTACLE: 220 volts from the *straight* pins of the RECEPTACLE.
120 volts between the *straght* slots of the RECEPTACLE and either of the *round* & "L-shaped" ground/earth slots of the RECEPTACLE.
If any of this is incorrect---contact an electrician.
Edited by john63, 09 June 2011 - 09:18 PM.
Musty odor
L-O-N-G cycle times
Suds error message
Slow spin speeds
Read below:
HE 3X: (1) Teaspoon
#7
Posted 09 June 2011 - 09:29 PM
Check and re-set the House Circuit Breakers.
#8
Posted 10 June 2011 - 08:05 PM
#9
Posted 10 June 2011 - 08:23 PM
yes, it could ..... I swear I checked it before and was getting 120V on each leg. But the dryer was still connected, maybe that's what caused the difference in readings
and you tried re-setting the Circuit Breaker ?
seems like the Circuit Breaker just needs replacing
Usually can easily be done by HomeOwner
#10
Posted 18 June 2011 - 06:06 PM
#11
Posted 18 June 2011 - 06:38 PM
... Lesson learned:
RepairClinic Return Policy
365 Days. Period. You may return any part or product for any reason within 365 days of placing your order.
(Including electrical parts that have been installed)
#12
Posted 18 June 2011 - 06:48 PM
#13
Posted 18 June 2011 - 07:12 PM
The 70 MV reading between legs was the sign that you had an electrical problem.
www.eliteapplianceservice.org
#14
Posted 18 June 2011 - 07:14 PM
Yep, I learned a lot from this. But now I know for the nest problem.
#15
Posted 18 June 2011 - 09:46 PM
#16
Posted 19 June 2011 - 11:16 AM
