Admiral Washer Brake Rotor Romoval LNC6760B71
2 replies to this topic
#1 Jason Jones
Jason Jones
  • 2 posts
  • Flavorite Brew:MGD
Posted 09 June 2011 - 09:57 AM
I am wanting to replace the brake rotor and it is calling for a special tool, due to the tension the spring is under (allegedly 200lbs or so). Is there a tip or trick with using normal tools without having to buy the special tool for this one time fix?
Jason
#2 certified tech group 51
  • 2,662 posts
Posted 09 June 2011 - 10:49 AM
Is this the one with the sticker that sez......"Do not remove cover, spring under 200 pounds.. etc..",,,,,,,,On the Maytag gearboxes, what you would do is remove one screw and go to the hardware store and get 1/2 the amount of screws in the gearbox ( 12 screws , get 6 ),, screws of the same thread but about 2 inches long......On the gearbox, remove alternating screws , like every other one ( on Maytag there is 6 screws ) install the new long screws all of the way, remove all of the old short screws, Then CAREFULLY remove the long screws about two turns at a time on every screw, working around the cover.....IF the cover is not loose as you are running out of threads, you need longer screws.... Reinstall in the reverse order using the long screws to suck the cover down, install the short, original screws and so on....
#3 Jason Jones
Jason Jones
  • 2 posts
Posted 09 June 2011 - 11:30 PM
hahaha....OMG....that is awesome...so simple, but I would have NEVER thought of it. You guys rock!
Blessings,
Jason
How to remove the brake rotor on Maytag Atlantis and Admiral washers without having to buy that expensive special tool
By Samurai Appliance Repair Man in Samurai Appliance Repair Man's Blog, on 09 June 2011 - 11:53 PM
Is this the one with the sticker that sez......"Do not remove cover, spring under 200 pounds.. etc..",,,,,,,,On the Maytag gearboxes, what you would do is...
Read Full Entry →
