jared515
Whirlpool WFW9150WW error code
5 posts in this topic
Hello all knowing people, I come to you as everyone else on this forum has, in search of an answer. I have a Whirlpool washer wfw9150ww that decided 20 days past its 1 year warranty, it was going to take a shit on me. Now, I have error codes, but for the life of me, I can't figure out when it starts, or when it stops, or to count this or that. So, I have uploaded a video for anyone that can help me out. This is the second time this POS has given me problems. The first time was a cracked plastic basket- thankfully under warranty, but if it hadn't been, would have costed $900. For anyone that can help me, I truly would appreciate it.
That is the link. Again, thanks for the help.
Pull the tech sheet from within the lower access panel and see what the codes are, you appear to have a "1-9" or "9-1" code
F9E1 (91) LONG DRAIN
If the drain time exceeds 8 minutes, the water valves turn off.
Possible Causes/Procedure
- Ask the customer how much detergent they are using and if it is HE detergent.
May have too much suds present causing this condition.
- Turn washer ON to verify pump operates; run the drain cycle.
- Check the drain hose and make sure it is not plugged or kinked.
- Unplug washer or disconnect power.
- Make sure that wire harness connections at the Drain Pump, Pressure SW, & CCU (DP2, PR6 cavities)
connectors are not broken or with wires detached, and that connector internal pins are visible.
- Check continuity from the Drain Pump & CCU (DP2 cavity) connectors.
- Check continuity from the Pressure SW & CCU (PR6 cavity) connectors.
- If the continuity diagnosis failed, Main Harness must be replaced.
- Make continuity test to the Pressure SW. See page 7.
- Check the resistance of the motor pump. See page 7.
- Plug in washer or reconnect power.
- Run the drain cycle.
- If the failure continues, unplug washer or disconnect power.
- Check the drain pump filter for foreign objects.
- Disassemble the drain pump from the washer.
- Check that the impeller is not detached from the motor shaft.
If the impeller is detached from the shaft, is broken or has any scratches, the drain pump must be replaced.
- Verify the washer operation by performing the Diagnostic Test cycle.
See page 5.
- After the diagnostic test has finished, unplug washer or disconnect power and wait for 15 seconds.
There ya have it - the old golf pencils in the pump trick
Wow, that was some quick feedback. Thank you. I will be trying those right now.
Thanks again.
