SAMSUNG RSG257AARS/XAA Service Manual?
4 replies to this topic
#1 phillymac1
phillymac1
    Ikkō-ikki
  • 42 posts
  • Flavorite Brew:Red Stripe...its beer!!!
Posted 10 June 2011 - 04:47 PM
Wanted to know if you guys have a service manual for samsung RSG257AARS/XAA? Here's the issue I'm having, refrigerator compressor nor evaporator fan is working, tried unplugging unit for a few min, but same issue when its plugged back in, on the panel it read "of" on both freezer/fridge temp display. So I go round back where board is and put into diag mode, in which it displays "88" for about 30 sec then back to "0f". I check for led flashes from board to see what issue the fridge maybe having, but doesn't come on at all, have anyone experience this problem or what I may need to check
Phillip
#2 appl.tech.29501
appl.tech.29501
  • 8,027 posts
Posted 10 June 2011 - 04:58 PM
sounds like the unit is actually turned off on the display but usually unplugging will reset.
we'll try and locate some info. for ya.
#3 appl.tech.29501
appl.tech.29501
  • 8,027 posts
Posted 10 June 2011 - 05:11 PM
does this unit have "power freeze" and "power cool" buttons ? If so, press them both for 5 seconds and see if the compouter resets and the compressor comes on.
#4 phillymac1
phillymac1
    Ikkō-ikki
  • 42 posts
Posted 10 June 2011 - 05:59 PM
Well whaddaya kno, it cranked back up, it needed to be reset, I thoght by killing the power would do that but it must hold its memory for awhile...I'll keep a eye on it to see if anything changes...thanks 4 the help!!!
#5 appl.tech.29501
appl.tech.29501
  • 8,027 posts
Posted 10 June 2011 - 08:40 PM
glad to help
How to reboot a Samsung refrigerator that's not running and showing "of" in the temperature display
By Samurai Appliance Repair Man in Samurai Appliance Repair Man's Blog, on 11 June 2011 - 08:24 AM
View Postappl.tech.29501, on 10 June 2011 - 05:11 PM, said:
does this unit have "power freeze" and "power cool" buttons ? If so, press them both for 5 seconds and see if the computer resets and the compressor comes on.
Source:...
Read Full Entry →
