frigidaire washer fafw3511kwo
8 replies to this topic
#1 warmock
warmock
  • 4 posts
  • Flavorite Brew:Beer
Posted 11 June 2011 - 02:25 PM
Have a fairly new frigidaire washer and the other day it started beeping so i went and unplugged hoping to reset it. Now all it does is show 18h PAU on the display and if you try anything it just says err. Anyone experience this before. Any input would be appreciated
thanx
Steve
#2 appl.tech.29501
appl.tech.29501
  • 8,025 posts
Posted 11 June 2011 - 02:30 PM
i'm pretty sure that's a bad electronic control...let me do some checking
#3 appl.tech.29501
appl.tech.29501
  • 8,025 posts
Posted 11 June 2011 - 02:46 PM
wake up the washer by pressing any button then hold down start/pause and cancel for 5 seconds, it should show an error code
#4 warmock
warmock
  • 4 posts
Posted 11 June 2011 - 10:13 PM
pressed the start/cancel and cancel button and all the display does is show (err) nothing else tried several times.
#5 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 11 June 2011 - 10:42 PM
To clear latest stored error code:
• Turn the Program Knob to the start position, Spin Only.
• Press Start/Pause to start the cycle and save it.
• Press Cancel to stop the cycle and turn off the LEDs.
• Press Cancel again to turn on the LEDs.
• Within 5 seconds, press and hold the Option and Start/Pause buttons until LEDs start sequentially chasing, then release buttons.
• Turn the program knob clockwise 7 clicks from the Start Position. The control will signal the last error code.
• Press and hold the Options and Start/Pause buttons for 3 seconds. The code will be cleared.
• Exit Diagnostic Mode to return the washer to normal operation.
a ) Unplug the power cord, wait 5-8 seconds, then reconnect the power cord
OR
b ) Turn the program knob clockwise 2 or 3 clicks after the Start Position.
Press Options and Start/Pause buttons together for a few seconds until wash cycle LEDs appear.
#6 warmock
warmock
  • 4 posts
Posted 11 June 2011 - 11:46 PM
I tried all of your instructions but the knob to turn to different settings doesnt do anything can spin it around and around but it is stuck on Heavy and if i push the buttons it is unresponsive other than the err I get on the display.
#7 Budget Appliance Repair
  • 4,926 posts
Posted 12 June 2011 - 05:56 AM
If the only thing that comes up on the display is PAU and every time you push any buttons it shows ERR and is the same after being unplugged you have a bad main control board.
One other thing, make sure it's not set to child lock, I'm pretty sure it's not - I think if it were in the child lock mode the display would show LOC when any button is pushed.
William Burk (Willie)
Eureka, CA 95501
#8 warmock
warmock
  • 4 posts
Posted 12 June 2011 - 07:47 PM
OK thanx will find out on monday if it is still covered by warranty or not. If it is not I will order a new control board. Thank you everyone for your replies.
#9 RegUS_PatOff
  • 33,588 posts
Posted 12 June 2011 - 08:13 PM
... will find out on monday if it is still covered by warranty
looks like it could be . . .
Your appliance is covered by a one year limited warranty.
For one year from your original date of purchase.
