rwbrick
Kenmore Elite dryer narcolepsy
12 posts in this topic
Kenmore Elite (fancy LED displays and push panel "switches" dryer, model 110.60092991, periodically goes to sleep.  Pushing any of the control buttons does/displays nothing.  Occasionally, if I press "Start" first (sometimes two times) then press the select button it will light up and let me finish the setup; then with "Start" it works fine.
It goes into this mode from time to time and it lasts from a couple of days to a month or two (so far...).  Power feed is O.K. (drum lamp comes on.)  Does this mean the whole circuit board is kaput?  Or might it be a faulty push-panel switch contact? Or maybe a loose low voltage feed, or some such?  Or what might be the problem?
Thanks.
Wow!  Thanks, Pegi at Sams.  :D  I'll check it out.
You are quite welcome...sorry about the two names, having to post two different ways here from the house.......:P
i am having the exact same problem with my dryer. sometimes i can hear it beeping non stop, other times the display is dead. The dead spots last from a few minutes, to a few days. Amazing. I am glad to hear i am not the only one with the problem, and the tech sheets should help me fix it...thank you so much:):):):):)
I took it (the electronics area) apart and preformed the LED tests with a multimeter and did some voltage tests on the circuit board after back engineering a partial schematic.  The latter is not easy as all contacts are lacquered over, and it was very sparse, but the readings I did take seemed O.K. (I'm an electronics hobbyist, so the little that I did is probably accurate.)  The Leds tested O.K except 1 or 2 anamolies where the LED(s) tested O.K. in the reverse direction :shock:.
It still doesn't work and I have to guess whether the circuit board or the display is bad so I don't end up buying both parts unnecessarily (??) at probably ~$150 +/- apiece.  I'm leaning toward the circuit board.
But, it kinda works.  When I plug in the power at the wall it clicks and randomly comes on, sometimes with heat (at different settings), sometimes without heat.  An odd array of ther little LEDs on the right side come on, but none of the LED display actually works.  When I get a lucky plug-in, I leave it and turn the dryer "on and off" with the loading door.  'course I have to manually keep and guess at the timing.
Anybody have any more clues.  The tech sheets were a big help, though a schematic would have been nice, but not expected.  :?
The wiring diagram is in the tech sheet....if it is too small to see the tech sheet will be located inside of our unit somewhere also..
Also bear in mind that if you buy through the link at the top of the page, you can return anything for a full refund less shipping. My experience is that generally, the board is the problem.
Thanks for the continued help, Pegi.  But I was referring to the schematic not the layout diagram of the circuit board, nor the basic wiring connections of the dryer.
Mad Mac, the circuit board would have been my guess.  Though I'm surprised; non-mechanical electronic stuff should be more robust and reliable.....
:laffinatchoo::laffinatchoo::laffinatchoo::laffinatchoo::laffinatchoo:
Nothing personal, you understand. Much more grief with the electronics than anything else.
Mad Mac,  no offense 'cause you are correct.  Problem is it need not be.  Other than electro-mechanical components, relays e.g., pure solid state electronics have the capability to be almost fail-proof.  Problem is the manufacturers "have" to save a half-penny on each 5-cent capacitor and a couple of pennies on each 59-cent integrated circuit -- maybe saving 15 cents or so on each mass produced circuit board that could be, and ought to be especially in a hostile environment like a clothes dryer, otherwise virtually error free.
