  • Announcements
Guest Bigpop
Whirlpool Gas Dryer No Heat
8 posts in this topic
Last night the dryer worked fine this AM the drum turns however no HEAT. After looking at the other post, I looked  through the hole in the front of the dryer & no glow,no fame, no heat help PLEASE deer season starts in 2days and cant leave my bride like this. Thanks in advance BIGPOP:cool:
[user=0]Bigpop[/user] wrote:
Last night the dryer worked fine this AM the drum turns however no HEAT. After looking at the other post, I looked  through the hole in the front of the dryer & no glow,no fame, no heat help PLEASE deer season starts in 2days and cant leave my bride like this. Thanks in advance BIGPOP:cool:  SORRY i had to find my glasses  Mod# LGR4634JQO  its heck to get old ..:yikes:
First check the white plastic thermofuse on the vent housing, reference #6 in this breakdown, if this is open it kills the heat circuit on the gas dryers if the air flow from the dryer is blocked to the outside.  If it tests good on your ohm meter check the igniter on the gas valve assy, as it could be broken.
Your igniter is reference # 4 in this breakdown, located on the side of the gas valve assy.  If both of these parts test good we can go further with instructions.
First Thanks for the help!!  Ok do I test the igniter the same way? just test for conti. make sure the circut is not open?
Yes, that is correct.  Be sure to remove the wires from the fuse and un-plug the ignitor to test them and this is with the dryer un-plugged also..
WOOO HOOOO!!!  Thanks for all your help you are the godess of dryers!  lol  I tested the fuse and it was bad, replaced it and a new vent hose just because it was already off. Beers and Cheers for PEGI !!!  :party::gimmebeer:  now its off to west Texas !!!  thanks again Bigpop.
LOL, you are quite welcome....have a good time in West Texas....:cool:
