How To Set Hotpoint CTX24GLR Defrost Control
#1
Posted 17 June 2011 - 04:55 PM
I suspect the defrost control needs to be set because the refrig. quit working and I found the coils in the back of the top freezer compartment completely iced up.
Someone (previous owner) has drilled a hole in the center of the control panel between the freezer and refrigerator temp controls. Behind this is a control which I suspect is the defrost control.
I have tried to find a service manual for this unit but had no luck.
All I need is to know how to set this control.
Can anyone help?
Chuck
#2
Posted 18 June 2011 - 01:40 PM
Your unit is comprised of a 3 component defrost system
including the timer, bi-metal, and a heater.
If you have excessive frost build up on the evaporator
coils or it's clogged completely then yes you have a defrost
problem.
now all you have to do it figure out which of the components you need.
the defrost timer is located in the control housing inside of the
refrigerator section and yes there is a hole there to advance the timer for testing.
Item # 646 on diagram below
if your coils are still clogged all you have to do is slowly advance the timer
clockwise with a screw driver "click by click" and when you reach the defrost mode you will
hear the compressor and freezer fan shut off.
When in defrost mode if the heater thats around the evaporator coils
imediately comes on the you have a bad timer. the heater can be checked by
touch "be careful" or with an amp meter.
If the heater is not getting hot then you either have a bad bi-metal
or a bad heater. the heater can simply be OHM'd out for continuity
and so can the bi-metal (as long as it's still covered with ice/frost)
If it's not you can submerge it into a glass of ice water for a few minutes.
Timer Link (if needed) Bi-Metal Link (if needed) Heater Link (if needed)
www.eliteapplianceservice.org
#3
Posted 18 June 2011 - 11:38 PM
I found the control about a half turn away from the cutoff point.
Thanks for the help,
Chuck
#4
Posted 19 June 2011 - 12:01 AM
Chuck
#5
Posted 23 June 2011 - 01:41 PM
I purchased and installed a new one.
I started the refrigerator by rotating the defrost control one click past the test point.
Is there anything else I need to do?
Thank You,
Chuck
#6
Posted 23 June 2011 - 01:44 PM
Topics merged.
#7
Posted 23 June 2011 - 04:11 PM
#8
Posted 23 June 2011 - 06:17 PM
I removed the rear cover in the freezer and found the right half of the lower row of coils are covered with quite a bit of frost
Help!
Chuck
#9
Posted 23 June 2011 - 06:20 PM
#10
Posted 23 June 2011 - 06:42 PM
post picture somewhere... right half of the lower row of coils are covered with quite a bit of frost
then post link here
#11
Posted 23 June 2011 - 07:28 PM
I removed the cover on the back and check. The coils are clean and the fan there is running also
#12
Posted 23 June 2011 - 08:29 PM
#13
Posted 23 June 2011 - 09:28 PM
#14
Posted 23 June 2011 - 10:29 PM
#15
Posted 23 June 2011 - 10:32 PM
#16
Posted 23 June 2011 - 11:02 PM
How to troubleshoot and repair defrost system problems in a Hotpoint (GE) refrigerator
By Samurai Appliance Repair Man in Samurai Appliance Repair Man's Blog, on 18 June 2011 - 02:41 PMThere's no "setting " of the defrost timer, it keeps its own time.
If you have excessive frost build up on the...
Read Full Entry →
