colt86
Maytag mfd2561hes fridge and freezer not cooling and compress fan not running
5 posts in this topic
I changed my Maytag mfd2561HES fridge relay 6 months ago with a 3 in 1. It worked great for 5 months. Now the fan near the compressor is not running and the compressor is cool to the touch. The refrigerator is still humming and I am assuming that is the internal fan. The refrigerator is holding at 55 and the freezer is holding at 38.
Last time the the fan was working just fine now its not. Is replacing that fan the only problem or is there more to it?
I am assuming replacing the 3 in 1 isn't the answer.
What was the reason for installing the 3 in 1 ?
If it was because of a Compressor Start / Run problem that a normal Start Relay wouldn't fix,
may now have a bad Compressor that also took out the Controller Board.
You could try applying 120v (L1) to the Blue wire of the Compressor or it's Fan
Service Test Mode:
The service test functions are performed using the refrigerator display and keypad.
Enter the Service Test Mode by performing the following sequence of events.
1. Open the Fresh Food door and press and hold the Door Alarm keypad DoorAlarm .
2. Press and hold Refrigerator Temperature UP keypad .
3. Release the Door Alarm Keypad DoorAlarm and wait 3 seconds.
4. Press the Refrigerator UP Keypad again.
5. Display will show 001 in left display and numeric or dashes in right display.
6. Press Freezer Up keypad and Freezer Down keypad to toggle through Service Test numbers.
Service Test – 101 Defrost Heater & Defrost Circuit
• Press the Refrigerator Up keypad and Refrigerator Down keypad to energize or de-energize the Defrost circuit.
The display will read OFF when de-energized OP when energized with open defrost thermostat and CL when energized with closed defrost thermostat.
Service Test – 102 Compressor / Condenser Fan
• Press the Refrigerator Up keypad and Refrigerator Down keypad to toggle Compressor/Condenser fan On and Off.
I dont have a background in any of this. Last time i was told to do a continuity check on the Compressor and it was fine so I was told to change the overload relay switch and that using the 3 in 1 was easiest and cheapest. It fixed the problem.
Now I am trying to remember how I did the continuity check.
Also last time the fan in the back next to the compressor was running. This time it is not. Does the fan running or not help in diagnosing the problem.
On the 101 Test it said OFF. I didn't know what setting to turn it to.
I did the service test from last email. On the 102 test it said OFF. When i turned it to ON it sounded like something turned on but turned off by the time i got to the back again so not sure what that sound was.
... by the time i got to the back again so not sure what that sound was.
...was the Fan still running ?
No the fan was not running. I had the back off already so it didn't take me long to get there.
Not sure if this means anything but, there is still semi cool air going into the fridge and freezer. the fridge has gone up from 55 to 58 from yesterday last day. The freezer is up from 32 to 42 from yesterday to today,
