bosch dw shu3032uc/u12
2 replies to this topic
#1 tars
tars
    Yamabushi
  • 97 posts
Posted 23 June 2011 - 01:12 PM
I have take entire dw apart and checked for anything that would cause it not to drain, when i advance the timer it drains just fine. After cycle is complete there is alot of water left in the bottom of machine. Im thinking the timer is not staying in the drain long enough. Any thoughts?
    Shōgun
  • Master Samurai Tech
  • 31,409 posts
Posted 23 June 2011 - 01:57 PM
I'm thinking restricted drain hose. Use a flashlight and watch the discharge stream as it flows into the kitchen sink drain. Should be full-bore and vigorous. If it's a weeny flow that comes in quietly and tapers off as soon as it exits the drain hose, then it's a restricted drain. Could be pinched or something caught in it. Or the drain pump could be bad.
Drain pump has been upgraded in this dishwasher, too. Added more impeller vanes to improve flow. Part link ==> Drain Pump and Motor
#3 tars
tars
    Yamabushi
  • 97 posts
Posted 23 June 2011 - 02:43 PM
Ok. Thanks.
