Bosch Double Oven Model #HBN755
2 replies to this topic
#1 deanfaw1
deanfaw1
    Yamabushi
  • 66 posts
Posted 23 June 2011 - 03:49 PM
Bosch Oven door lock issue F42 Error Message- how do I approach this issue? What do I look for?
#2 RegUS_PatOff
  • 30,272 posts
Posted 23 June 2011 - 04:12 PM
has the Self-Clean been used lately ? :nono:
F42 Lower Motorized latch will not lock.
Defective or jammed lower oven door or latch switches.
Defective latch Motor or its wiring.
1. Check P24 connector on the Power Board.
2. Ensure door latch switches are operating properly.
3. Check that neither latch switch nor common wires are pinched to the appliance chassis.
4. Check P10 connector and check if latch Motor wire is pinched to the appliance chassis.
5. If F42 persists, replace Power Board.
#3 deanfaw1
deanfaw1
    Yamabushi
  • 66 posts
Posted 23 June 2011 - 04:20 PM
Thanks for the reply. It turned out to be a bent door switch plunger spring kinda tricky but I found it.
Edited by deanfaw1, 25 July 2011 - 10:40 PM.
