Amana ALE866SAW electric dryer
3 replies to this topic
#1 Wayne02
Wayne02
    Ikkō-ikki
  • 26 posts
Posted 24 June 2011 - 06:09 PM
Our beloved Amana commercial super capacity craigslist special may be down for the count. We have had this machine for many years and it has been a workhorse, paid $35 for it off CL. I've replaced the drum felt seals at least once, and repaired something else on it years ago (can't remember).
A family member recently severely overloaded the dryer and it started making an intermittent screeching noise after that. We are talking an ear splitting screaming sound, and the drum has a lot of movement up and down. I figured maybe drum felt seal or wear glides but upon disassembly I found:
- belt was fine and seemed to have good tension
- rear drum support wheels still moving freely and little or no play
- rear drum felt seal perfectly intact with very little wear
- front drum felt seal intact save for right at the top where it was worn through and split
- glides in good shape (note, there were two glide strips on each side and one side appeared to be shimmed up with a piece of felt under the two glides. Is it normal to have two glides stacked on top of each other like that?
- idler pulley was turning but not freely, it was bound up
I took everything out of the cabinet save for the electric motor and the blower/lint trap system (under the door on this model). I then ran the electric motor with no load and the screeching is coming from the motor itself. The noise is not as consistent as it is when there is a load on the motor, but definitely there even with no load.
It looks like an electric motor can be purchased but I'm just wondering about putting that kind of money into such an old unit. Can the electric motor be rebuilt or repaired?
#2 john63
john63
    Dean of LG Appliantology
  • 2,211 posts
Posted 24 June 2011 - 06:29 PM
<<<Can the electric motor be rebuilt or repaired?>>>
No.
The MOTOR can be replaced (somewhat expensive though). On the plus side---you are *familiar* with this dryer & capable of self-servicing it.
Home Depot has an Admiral-brand dryer that is fairly inexpensive and a very common design (easy to service).
Admiral dryers are simply rebadged/relabeled Whirlpool dryers (built by Whirlpool).
<<glides in good shape (note, there were two glide strips on each side and one side appeared to be shimmed up with a piece of felt under the two glides. Is it normal to have two glides stacked on top of each other like that?>>
The FRONT DRUM GLIDES normally have a single *glide* with a single small *felt* underneath.
Edited by john63, 24 June 2011 - 06:34 PM.
To eliminate:
Musty odor
L-O-N-G cycle times
Dingy/yellowing whites
Suds error message
Slow spin speeds
Read below:
HE 2X: (1) Tablespoon
HE 3X: (1) Teaspoon
#3 Budget Appliance Repair
  • 4,932 posts
Posted 25 June 2011 - 07:07 AM
Some did come from the factory with two glides stacked on top of the felt pad. I don't know if maybe they were a thinner glide or what but with the new glides trying to stack two on top of the felt really pinches the felt seal at the bottom and leaves a major gap at the top.
If you replace them just replace with a single glide and if the glides haven't worn completely though you shouldn't have to replace the little felt pad under the glides, (just glue back in position if the pads are loose).
William Burk (Willie)
Eureka, CA 95501
#4 john63
john63
  • 2,211 posts
Posted 26 June 2011 - 12:32 AM
<<<Some did come from the factory with two glides stacked on top of the felt pad.>>>
Dang! Now that you mentioned it---I do recall seeing that as well.
I just passed it off at the time----as perhaps an owner-installed (DIYer) mistake.
To eliminate:
Musty odor
L-O-N-G cycle times
Suds error message
Slow spin speeds
Read below:
HE 3X: (1) Teaspoon
