bradleymac5
Maytag Dryer End of Cycle Chime not working
3 posts in this topic
End of Cycle Chime not working. Any solutions?
Maytag Atlantis Dryer MDG7600AWW
Ryan
Looks like from your wiring diagram, that the chime is part of the timer. Is that correct? You should be able to tell by opening the control panel and look for a bell built into the timer. If that's the case, you'll need a new timer.
The end-of-cycle chime is part of the timer on your dryer.
If the chime is no longer working, only way to fix is to replace the timer.
Here's the part you will need: 33001932 Timer w/chime CLICK HERE to see and/or order.
