  • Announcements
Sign in to follow this
Followers 0
cbrown
Dead microwave?
6 posts in this topic
My Kitchenaid combo microwave/oven unit no longer has a working microwave. The keypad just beeps three times when you press any of the microwave functions. The keypad is operational, as the numbers work fine with the lower oven (microwave and oven share numeric keypad). The clock works and can be set. Also, the light is off in microwave. No error codes are displaying, though I'm not sure if I have to do something to cause error codes to appear. Suggestions?
Model # for above post is KEMS377d.
Thanks for any help. Would really help the marriage temperature around here.
are there a few missing letters/numbers at the end of your model number ?
No. It's a KitchenAid Superba combo unit. Oven lower, micro upper. KEMS377D and KEMS307D.
disconnect power to the unit and lay the control panel down
it's held in place by a few screws around the perimeter.
There are (2) fuses....1 in the front of the control compartment
and 1 towards the back to the right (big fuse)
Remove the fuses and OHM them out using a meter.
Time Of Day Fuse Link 20A
Line Fuse Link
model number from appliance, not from paperwork
missing characters denote color and engineering changes (parts & wiring)
KEMS307DAL1
KEMS307DAL2
KEMS307DAL4
KEMS307DAL6
KEMS307DBL1
KEMS307DBL2
KEMS307DBL4
KEMS307DBL6
KEMS307DBS0
KEMS307DBS2
KEMS307DBS4
KEMS307DBS6
KEMS307DBT6
KEMS307DWH1
KEMS307DWH2
KEMS307DWH4
KEMS307DWH6
KEMS377DAL2
KEMS377DAL4
KEMS377DAL6
KEMS377DBL1
KEMS377DBL2
KEMS377DBL4
KEMS377DBL6
KEMS377DBS0
KEMS377DBS2
KEMS377DBS4
KEMS377DBS6
KEMS377DBT6
KEMS377DWH1
KEMS377DWH2
KEMS377DWH4
KEMS377DWH6
Followers 0
