dsergison
ge front load washer wsxh208a1ww
3 posts in this topic
front load washer, it will not agitate after fill, it will spin out if you advance the timer to the end of cycle. motor runs fine both directions during pre-spinout, spins out fast. so I don't suspect the motor control board.
The washer refuses to actually do any agitating it will not proceed after filling at beginning of cycle.
I suspect the timer?
Drive motor spins but does not tumble.
Set the timer to tumble.
Disconnect the six & ten pin plugs from the speed control board.
Measure the voltage drop between pin 5 (neutral) of the six pin plug
to the following pins of the ten pin plug
pin 1 =
pin 2 =
pin 6 =
pin 9 =
pin 10 =
