Please Help! With Icemaker Repair
4 replies to this topic
#1 Rocky
Rocky
  • 3 posts
Posted 26 April 2005 - 06:25 PM
Could you please guide me on the next repair step for me?  I have a Kenmore Model 106.70102000 Model Refrigerator no longer making ice.  This model has a water dispenser behind the door and it isn't working either.  I just replaced the water inlet valve/solenoid at the bottom of the refrigerator and there's still no water or ice.
Could you please advise on the next step to take?  Thanks!
  • 24,207 posts
Posted 27 April 2005 - 03:16 AM
Initiate the harvest cycle on the icemaker and see if it cycles and fills toward the end of the cycle.  Also, listen for the fill valve to energize toward the end of the cycle-- you'll hear a hum that lasts for about 5 seconds.
#3 Rocky
Rocky
  • 3 posts
Posted 27 April 2005 - 01:45 PM
Hi Samurai!
I just finished replacing the second solenoid (double) valve.  I was able to get the unit to cycle through and there is now water in the tray and I have water coming behind the door now too.  Hoping to hear the fall of icecubes soon!
#4 Rocky
Rocky
  • 3 posts
Posted 28 April 2005 - 07:08 PM
:yikes:I have ice cubes falling, but they are hollow.  Any ideas on what is wrong?
  • 24,207 posts
Posted 29 April 2005 - 04:43 AM
This is caused by low water pressure: supplying water from a reverse osmosis filter, gunked up saddle tap valve, sediment in the water inlet valve, ...
