Mr_Peables
Washer tub won't spring back into position. Water flow misses tub.
4 posts in this topic
Admiral Mod. # LNC6760B71
HELP, :yikes:   My wife is a few days from running out to buy a new washer. This one's only 2 years old!!   The problem is that  as the washer fills, water spills over the top rim because the washer tub won't spring back into position and isn't centered. I checked the springs and they are all there and in perfect shape, but it's as though they aren't strong enough to pull the tub in center. If I help it, it will move easily. Can something be replaced at the piviot point?
Mr. Peables
I have read posts about a replacement spring kit for that problem I believe, stronger springs, perhaps one of the other techs in here can confrum this and supply the part number??   ;)
Hi,
Doing my research, I read that sometimes the damper pads need to be replaced. Any comments...Any truth to that? How hard a job? Part #?
Mr Peables
More info on that kit in this thread.
