Miele Washer W1986
3 replies to this topic
#1 appl.tech.29501
appl.tech.29501
  • 8,025 posts
Posted 29 June 2011 - 05:25 PM
Have a customer with the above machine Miele W1986
showing intermittent F6/F7 faults that she states only
happens when she's washing towels.
Those faults are for water inlet and drain
She uses the same setting for all clothes types
set to 120 degree rinse
The "rinse" is where the fault occurs so i'm
assumming that the problem is in one of the valve
but that has nothing to do with the load size which she insistes
is a factor.
Component check in dignostics reveals no problems
Anyone happen to have this problem before?
#2 kdog
    RoughShod
  • 7,466 posts
Posted 29 June 2011 - 06:51 PM
I believe that is the wash temperature - yes, sounds like a cold water valve (the tripple one) issue. Since the towels have a higher absorbtion rate, and the rinse level is higher than wash, it sounds as if it is timing out before it gets to the rinse level due to a partially blocked valve
#3 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 29 June 2011 - 07:50 PM
Using any "funny" supply Hoses ?
#4 appl.tech.29501
appl.tech.29501
  • 8,025 posts
Posted 29 June 2011 - 07:59 PM
Good thinking !!! Makes sense ...thats probably why it isn't showing on the component check either.
Not sure, haven't been there yet. I doubt it though, been working properly for 6 years.
