Find Appliance Parts & Diagrams Here
365-day return policy on all parts ordered through this site!
FAQs | Contact | Apprenticeship | Consultations | Parts | Repair Videos | Newsletter | Beer | Fixitnow.com
Welcome to the Appliantology Academy!
Feel free to browse around and get the feel of the place. If you need help getting going, come check out these short screencasts.
Making A Rukus During Spin Cycle - GE WCVH6260FWW
2 replies to this topic
#1 setotitan
setotitan
  • 5 posts
Posted 29 June 2011 - 05:54 PM
Well I posted here three years ago and got the advice to remedy my problem. I'm hoping I can have another round of luck today. I have a GE Front Loading Washer model: WCVH6260FWW. As I said, three years ago I had a bad inverter, let me link you that post in case it helps..
GE WCVH6260FWW - Need Help Install Inverter
I fixed that and everything's been A OK. However just today it started sounding horrible on the spin cycle. I mean just loud knocking like it's going to explode. On top of that there's some black gunk on the clothes when they come out. They're little dots in the shape of the inside washing drum. My wife tried to clean it earlier, but I don't know if that's just gunk breaking loose from where she cleaned or if it's symptom of the spin problem. I've always heard when you get knocking or a loud spin cycle "it's a counterweight that's come loose and the load isn't balancing right when it spins". This obviously is advice from laypeople who can only guess as to what's wrong, but of course have no idea how to fix it.
That's why I'm here, to ask a pro. Is it a counterweight, or something else, and more importantly is it something I can fix myself? Any and all helpful feedback is welcome. Samurai don't fail me now!
Looking for Appliance Parts?
Enter your model number, part number, or even a part description and find it here.
#2 KurtiusInterupptus
KurtiusInterupptus
    B.M.F.
  • 1,277 posts
  • Flavorite Brew:Killians Red
Posted 29 June 2011 - 06:20 PM
Do this test...
open washer door and grab the top edge of the inner wash basket
push straight up on the basket while steadying the outer drum with your other hand
is there any lateral movement? Or is it tight and secure?
hope for the latter, because the former is the telltale sign of a worn bearing, a broken support spider or both...not worth repair if this is the case.
If all is good here, go around back and take off the cover. Look for a loose pulley on the basket shaft.
of course the counterweights could be loose but you don't need me to tell you how to check this.
Edited by KurtiusInterupptus, 29 June 2011 - 06:22 PM.
#3 setotitan
setotitan
  • 5 posts
Posted 30 June 2011 - 07:32 AM
Shoot, just now checking this that I am at work. I'll try what you suggested as soon as I get back home, I'd ask my wife to do it, but I don't know if I'd trust her answer. HAaHaha!
How to tell if you have a worn tub bearing or a broken drum suport in your front loading washer
By Samurai Appliance Repair Man in Samurai's Blog, on 30 June 2011 - 08:52 AM
Do this test...
hope...
Read Full Entry →
