whirlpool duet wfw9200sq00
4 replies to this topic
#1 snowman
snowman
  • Appliantologist
  • 3 posts
  • Flavorite Brew:corona
Posted 29 June 2011 - 06:42 PM
whirlpool duet washer - push power on - door locks- water enters - stops cycles off lock then locks this is normal. Then just sits there no motor or water no drain motor if in drain spin. code for communation error comes on after 3 mins no elec to pump - windings good to pump.
#2 Strathy
Strathy
    Head Wrench
  • PipPipPipPip
  • 765 posts
  • Flavorite Brew:Coffee
Posted 29 June 2011 - 08:51 PM
What is the code number?
Neighbour's Appliance Service
Servicing Southern Manitoba, Canada
#3 snowman
snowman
  • Appliantologist
  • 3 posts
Posted 29 June 2011 - 10:09 PM
f-28 no main motor or pump run
#4 Strathy
Strathy
    Head Wrench
  • PipPipPipPip
  • 765 posts
Posted 29 June 2011 - 10:33 PM
OK ... going by memory here.
- First ohm out your motor. You should have approx 6 ohms between 1-2,1-3 and 2-3. You should also get 120 ohms on 5-6 which is the tach on the motor. If that is good ...
- Open up the little flap on the MCU board. Start a regular wash cycle and check for voltages at the MCU. On the pink wires you should get 120v. (With the wires connected to the MCU - don't disconnect them to check the voltage.) On the connector with the little blue wires - you should have 5 vDC.
- If you are getting the correct voltages at the MCU and the motor ohms out good, then you have a bad MCU.
- If you are not getting those readings at the MCU, then check continuity on the blue wires and the 2 pink wires from the CCU to the MCU.
- If you have continuity on all wires and the connections look good, then you have a bad CCU.
    Shōgun
  • Master Samurai Tech
  • 31,379 posts
Posted 30 June 2011 - 07:06 AM
Nice walk-through, Strathy! :dude:
How to troubleshoot an F28 error code in a Whirlpool Duet Sport washer
By Samurai Appliance Repair Man in Samurai Appliance Repair Man's Blog, on 30 June 2011 - 07:47 AM
- Open up the little flap on...
Read Full Entry →
