Maytag Neptune Dryer MDE5500AYW
1 reply to this topic
#1 daredman
daredman
  • 1 posts
Posted 30 June 2011 - 09:28 AM
I read the previous post, below, ordered the drum rollers and glide bearings, and replaced them but the squealing is still present.
http://applianceguru...7340&forum_id=2
What I've identified is the right post that holds the right drum rollers has a small about of black build up on it and below in the basin of the dryer I can see some shavings on the floor. Also inside the spindle if the drum roller, where it rides on the post, I can see this black buildup as well. I started a cycle and watched the roller, it would stop intermittently, thus causing the loud squeal over and over again. So I sanded the inside of the roller as a test and sanded the post as well until all were clean then repositioned - ran a cycle and it was perfect. The next day the squeal was back. So I wanted to know if it's safe to put some kind lubricant on the post or is that a bad/dangerous idea. I noticed the heating element is directly below which concerned me with any kind of dripping and fire. Is the post difficult to replace if I have to?
#2 SANTA
SANTA
    Senpai
  • PipPipPipPip
  • 699 posts
Posted 30 June 2011 - 10:20 PM
You'll have to replace the post OR you can try loosening the post and giving it a half turn so the bad spot is on the bottom. The hard surface has worn off. I would replace the post but it's up to you. Click this for your part. http://www.repaircli...3129480/1480353
Edited by SANTA, 30 June 2011 - 10:23 PM.
