Whirlpool Duet Sport Electric Dryer - Model #WED8300SW0
2 replies to this topic
#1 JanS
JanS
  • 2 posts
Posted 01 July 2011 - 10:52 AM
Ok..so here's where I am. I had a repairman here yesterday to work on my Whirlpool Duet Dryer. It was running but not heating. He replaced the heating element and the thermostat, to the tune of $300 parts and labor. After he left, I ran about a half of a load of clothes through the dryer, no problem. This morning I get up to do laundry and this time the dryer just beeps, clicks, and won't run. I ran the diagnostics and get the code F-26 which I know means motor drive system failure. What I am wondering is what exactly that means and what I'm looking at as far as fixing it? I talked to the repair place again and was told that they would come back free of charge, but if they determined that it was something different than what was done yesterday or didn't occur because of the call yesterday, then I would have to pay another $129 call and parts.
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 01 July 2011 - 11:23 AM
... code F-26 which I know means motor drive system
How's the white Thermal Fuse on the Blower Housing ?
http://www.repaircli...3740&locID=3436
you may have a Vent problem ...
Vent should be rigid metal.
NO plastic
NO PVC
NO screws
Foil Duct Tape is OK.
Check / clean the Dryer Vent
#3 JanS
JanS
  • 2 posts
Posted 01 July 2011 - 11:37 AM
Thank you for your reply. When the repairman left yesterday, I followed all of his advice and cleaned out all the venting areas inside and outside and shortened the vent hose so that it wasn't bent. From what I have read, I am suspecting the thermal fuse. I am not sure if they will look at it as being the same issue and not charge me for a return visit, or if I should try to just replace it myself before taking a chance on another couple hundred dollars.
