Maytag gas range CRG9800BAB
3 replies to this topic
#1 LostInIowa
LostInIowa
  • 9 posts
Posted 02 July 2011 - 02:35 PM
The owner's manual says you can't remove the stove top.
I need to get at the burner wires to troubleshoot why one burner won't click and won't ignite. All three others do.
How do I remove the stove top, or do I need to?
#2 appl.tech.29501
appl.tech.29501
  • 8,027 posts
Posted 02 July 2011 - 02:52 PM
you have to turn each burner head about 1&1/2" CCW to release it from the top of the range.
Once released you can lift it up and remove the wiring and the top can be raised after releasing
the clips under the front edge.
Note:
They make a special wrench for removing the burners
however you may be able to do it with some other type of large pliers.
you will need to take great care when removing as its normal
to hear a little cracking and poping of the porcelin when removing but, can
crack severly if you rough with it.
#3 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 02 July 2011 - 02:57 PM
sounds like a bad Burner Switch #5 on the Burner Control Shaft #1
When any Burner is turned ON all Ignitors should Spark
http://www.repaircli...?R=154&N=705158
#4 appl.tech.29501
appl.tech.29501
  • 8,027 posts
Posted 02 July 2011 - 03:16 PM
Could also be just a bad ignitor
Sealed Burner Link (Ignitor not sold seperately)
How to remove the stove top burners in a Maytag gas range
By Samurai Appliance Repair Man in Samurai Appliance Repair Man's Blog, on 02 July 2011 - 04:03 PM
the clips under the front...
Read Full Entry →
