MC
Whirlpool French Door GI6SDRXXB00
4 posts in this topic
My whirlpool french door bottom freezer works great with one exception. When the ice maker fills it sounds like an alarm clock going off, makes a harsh buzzing noise for about 5-10 seconds while filling. It sounds like the solenoid but it's hard to isolate, when using the water on the door there is no noise.
Most likely is a bad valve. the water utilizes a different one.
inlet valve link
Valve was bad and tech replaced it under warranty no problem.
Is there a way to remove the freezer drawer baskets without taking the whole thing apart.  I have checked the manual that came with it no information on taking freezer drawers out, plenty though on the upper section.
this may apply:
Freezer Drawer (some models)
1. Open drawer to fully open position.
2. Remove upper and lower basket.
3. Remove screws one in each rail marked on side of rail.
4. Lift front of drawer up and out to remove drawer.
5. Set drawer on a padded surface to prevent damage to finish.
