Whirlpool Gas Dryer, LGR4634JQ0
1 reply to this topic
#1 tigerlady1975
tigerlady1975
  • 1 posts
Posted 08 July 2011 - 11:22 AM
My gas dryer will heat sometimes and then cool air blows. It will run through the whole cycle when on the timed setting and shut off (clothes still wet after 60 minute cycle), but on the sensor settings the dryer will just run continuously. I have read that we should check the the ohms on certain things, how do we do this? Also, from everything that I have read, it seems as if it might be bad coils. We do not want to buy the wrong part, any suggestions?
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 08 July 2011 - 11:36 AM
... but on the sensor settings the dryer will just run continuously.
... it seems as if it might be bad coils.
1) Timed Dry uses the Timer.... with Sensor Dry, Timer isn't told to run until air reaches temperature
2) Gas Valve Coils ... common fail ... cheap fix
http://www.repaircli...sp?R=154&N=3479
