| Find Appliance Parts & Diagrams Here |
| Enter a model number, part number, type of appliance, brand, or even a part description. |
365-day return policy on all parts ordered through this site! |
FAQs | Contact | Apprenticeship | Consultations | Parts | Repair Videos | Newsletter | Beer | Fixitnow.com
Samsung DV337AEG Repair
#1
Posted 08 July 2011 - 05:40 PM
I have a Samsung DV337AEG/XAA dryer. It stopped heating today. Everything else works and I have no error codes on the front panel. I didn't see the repair manual for this on the forum but could sure use it if anyone has a copy. I've looked at the parts list and see that there's a thermostat, a thermistor and of course the heating element. According to my research, if the thermistor went out, there should have been an error code displayed. Since it's in series with the heating element, I would expect the same code of the heating element went out so my current suspect is the thermostat. Any clues out there?
Thanks in advance for the help.
Phil
Looking for Appliance Parts?
Enter your model number, part number, or even a part description and find it here.
#2
Posted 08 July 2011 - 05:49 PM
On the sheet---you'll find the test values for various components.
THERMISTORS can fail and still not trigger an error display. Check the OHMS value (at room temperature) with a test meter.
Edited by john63, 08 July 2011 - 05:50 PM.
Musty odor
L-O-N-G cycle times
Dingy/yellowing whites
Suds error message
Slow spin speeds
Read below:
HE 2X: (1) Tablespoon
HE 3X: (1) Teaspoon
#3
Posted 08 July 2011 - 06:15 PM
the thermistor detects temp changes in the dryer by changes in resistance, which are interpreted by the control determining when to turn the heat on and off...
#4
Posted 08 July 2011 - 06:59 PM
My wife was in the air force & lived in Falmouth for a number of years. Beautiful place.
The THERMISTOR has a *coating* on it that becomes scratched/chipped over time by tiny particles in the blower housing. The salty air then corrodes the THERMISTOR (no heat at all).
Musty odor
L-O-N-G cycle times
Suds error message
Slow spin speeds
Read below:
HE 3X: (1) Teaspoon
#5
Posted 09 July 2011 - 06:35 AM
PCG, here's the thermistor part link, if needed ==> Thermistor
Edited by Samurai Appliance Repair Man, 09 July 2011 - 03:10 PM.
Read More If we helped you kick some appliance bootay and saved you some coin, help us keep the lights on ==> http://beer.fixitnow.com
My In-Home Service Business ==> www.ApplianceGuru.com
#6
Posted 09 July 2011 - 12:37 PM
Just an FYI on THERMISTORS.
The 2nd most common cause of NO HEAT on Samsung electric dryers---would be the HEATING ELEMENT. Especially if the dryer is used fairly often (8 loads per week or more) or if the vent system is longer than 8 feet and has 2 or more 90 degree turns/elbows.
Musty odor
L-O-N-G cycle times
Suds error message
Slow spin speeds
Read below:
HE 3X: (1) Teaspoon
#7
Posted 09 July 2011 - 03:21 PM
john63, on 09 July 2011 - 12:37 PM, said:
I should have said "if needed" in my post. Edited.
