Kenmore/whirlpool oven 66575842004
6 replies to this topic
#1 deanfaw1
deanfaw1
    Yamabushi
  • Master Appliantologist
  • 79 posts
Posted 13 July 2011 - 10:19 AM
This unit uses a separate inline valve solenoid to let gas through to the cooktop of the range. There seems to be low voltage to this solenoid when the spark ignition is initiated but the gas does not make it past the solenoid. So I have deemed this a bad solenoid. I noticed that the original solenoid has been subed out with this part number 8184768 which appears to be a 120v solenoid. This has me doubting myself that it may be something else. The only thing I can think of is the relay (9752759) that feeds the voltage to the solenoid. I guess I should have tried using my cheater cord to open the original solenoid. Any advice on this one guys would be much appreciated. Thanks
Edited by deanfaw1, 13 July 2011 - 10:24 AM.
#2 kdog
    RoughShod
  • 7,466 posts
Posted 13 July 2011 - 11:45 AM
How low ??? should be within 10 percent (108-132 volts)
#3 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 13 July 2011 - 12:03 PM
... should be within 10 percent (108-132 volts)
yes,
Tech Sheet - 8273767.pdf
link PM'd
http://www.repaircli...?R=154&N=786383
purchase helps keep this site running
OR
the The Beer Fund :pint1: :pint1:
#4 KurtiusInterupptus
KurtiusInterupptus
    B.M.F.
  • 1,888 posts
  • Flavorite Brew:Killians Red
Posted 13 July 2011 - 12:47 PM
I assume you know this is a safety solenoid...it stays open all the time,not just when you turn on a top burner...
Unplug the unit and then replug...look at the scrolling message on the oven display...it will ask you to make sure all the burner valves are off and if so to press start or cancel...this will or should open the solenoid supplying gas to the top burners.
#5 deanfaw1
deanfaw1
    Yamabushi
  • 79 posts
Posted 25 July 2011 - 10:35 PM
KurtiusInterupptus you were right about this safety valve. I was only getting about 10v ac to it when I attempted to turn on any of the burners otherwise no voltage. I was getting the clicks but no gas. The display was not telling me how to unlock. It was just saying PF and I just hit the cancel button and it went away. Since this didn't deactivate the lockout feature and later the owner figured it out I feel like a total SAP. Couldn't charge anything for this misdiagnosis.
Edited by deanfaw1, 25 July 2011 - 10:38 PM.
#6 deanfaw1
deanfaw1
    Yamabushi
  • 79 posts
Posted 25 July 2011 - 10:53 PM
The real solution was listed in the tech sheet provided below by RegUS_PatOff
COOKTOP LOCKOUT
FEATURE (SOLENOID)
A normally closed (N.C.) electrical solenoid
is located on the back of the range that will
provide a means of shutting off the gas
supply to the cooktop burners. This 120-volt
solenoid is connected across the L1 and
Neutral sides of the line and controlled by a
relay on the microcomputer board. See
Strip Circuit, page 3.
The solenoid is held open to allow gas to
flow to the cooktop burners. If a customer
wants to “Lockout” the operation of the
cooktop burners, they can hold down the
TOP/TOP LIGHT keypad on the control
panel for 5 seconds.
See Use and Care
Guide.
This will open the relay and disconnect the
electrical supply to the solenoid. Once the
electrical supply is disconnected from the
solenoid, the solenoid will close and stop
gas flow to the cooktop. In the event of a
power outage, the gas supply to the
cooktop burners will be shut off.
#7 KurtiusInterupptus
KurtiusInterupptus
    B.M.F.
  • 1,888 posts
Posted 26 July 2011 - 01:17 AM
Thanks for posting that...obviously the same system as the couple of units I have seen, only not as fancy.
Imho...I am all for safety but damn....the genius's have engineered out the best thing about having a gas cooktop...being able to use the top during a power outage.
of course, we are all WAY to stupid to be trusted with such awesome power.
thank you mister regulator man for protecting me from my silly self...:-(
