LG bottom freezer lfx25960st
No replies to this topic
#1 mikeeb
mikeeb
  • 1 posts
  • Flavorite Brew:mikes
Posted 16 July 2011 - 12:57 PM
My defrost drain system is out of wack,the evap pan is dry. the water drains into the freezer. I took the fear panel(from inside the freezer) and thought I'd find a drain hole plugged.Hard to believe but i couldn't find any drain. the lip under the coils has a tin foil tape with no drain hole seen. What am I missing? It takes about 1 week until the water starts to leak out on the floor. Any help is appreciated.
