Sign in to follow this
Followers 0
Tsuriman
Frigidaire, dishwasher, FDBB2040FC1
7 posts in this topic
Greetings venerable ones.
The dishwasher leaks from the front corners about 15 minutes into the cycle, I am guessing when washing starts. It overflows at the corners in surges (sprays?) of water overloading the corners and spilling on to the new hardwood floors.
Deduced from wisdom already discussed, I think have narrowed it down to 2 possible problems. The front door seal or the split sprayer arm directing water onto the same seal. The pic is off what looks like might be a split on the sprayer arm but during the "hose test" water sprayed from all the appropriate places and not the seam.
The reason I checked the sprayer is because when I removed the seal it "looked" fine. This is the gasket listed for this model but mine also has little plastic tabs attached to the ends.
Thoughts?
ps "hose test" happened in the backyard, garden hose flowing full bore into the sprayer arm.
Edited by Tsuriman
P/M'd you the bulletin
Next time I search any problems with my Frigidaires I will throw "Friggy" in the search :-)
After reading I might be able to get away with an adjustment of the seal as I think it got knocked out of whack, but I went ahead and ordered the new seals for longevity. Plus, I know you guys need beer money :-P
DOMO ARIGATOU! As always, much appreciated.
:pint1:
Don't know what bulletin was PM'ed but here's one solution to that problem.
Frigidaire D/W lower door gasket leak guards
WCI 154701001 Splash shield kit
http://www.repairclinic.com/PartDetail/Gasket-or-Seal/154701001/1465007
The lower door seal strip is most likely OK and not the problem, I just had a three year old one of these Friggy D/W doing the same thing and this was the first time I've used this splash guard kit, it took care of the problem.
Also make sure the D/W is mounted level or even just a slight bit higher in front then back to make sure the water isn't pooling up to high in the front causing the surges in the corners.
P/M'd to Willie
First run was dry! Thank you :beermug:
FYI the main seal was to be marked at 3/8" from the bottom, mine barely stuck out 1/4", couldnt get it to grab. Anyway, with the front cover off I could see it was a pretty good seal. The side seals are a snap.
Followers 0
