GE Refrigerator PSI23NGNABB Defrost Problem
#1
Posted 17 July 2011 - 12:03 PM
Then about a month ago, the no-defrost problem returned, so I again replaced the defrost heater coil. When I examined the coil I'd pulled, however, I was a bit stumped because it had continuity and indicated the same resistance as the replacement coil. The frost returned, so I assumed that there was something else wrong.
I used a jumper to connect line and defrost leads on the motherboard, and the defrost coil immediately started to glow and defrost the freezer. So I assumed that the motherboard was bad.
I pulled the motherboard and found a burnt solder connection on the back of the board under the compressor IC, so I ordered and installed a new motherboard. I installed it and the refrigerator seems to run fine (although when I open the door, the refrigerator keeps running, whereas with the original motherboard, opening the door would cause the refrigerator to stop until the door was closed again). However, when I put the freezer through the #14 diagnostic test to defrost, the fans and compressor altered their operation, but the defrost heater didn't glow. I again jumped the line and defrost leads in the motherboard, and again, the coil glowed red and defrosted things.
What should be the next part(s) I replace?
Many thanks.
#2
Posted 17 July 2011 - 06:16 PM
#3
Posted 17 July 2011 - 07:17 PM
did you follow the instructions with the new Motherboard ?.. I ordered and installed a new motherboard.
(do NOT cut any wires for your model)
should be the same as 31-9072
#4
Posted 17 July 2011 - 07:45 PM
Tech Sheet_Page_2.jpg 168.4KB
18 downloads
Tech Sheet_Page_1.jpg 195.88KB
15 downloads
#5
Posted 17 July 2011 - 07:53 PM
did you folloe the instructions with the new Motherboard ?
Yes, I followed all instructions on the new motherboard. I skipped step 2 (eliminate thermistor wire) and step 4 (cut green wire in capacitor board) as both steps are only for people with bottom freezer units, and mine is a side-by-side.
And the main board I installed was a WR55X10942 as the GE website indicated this was the appropriate replacement for my unit.
#6
Posted 17 July 2011 - 08:53 PM
... I put the freezer through the #14 diagnostic test to defrost...
I'm not seeing the test referenced in the tech sheets you posted. What's your source for this?
#7
Posted 17 July 2011 - 09:06 PM
This link: http://www.mediafire.com/?dmyfyeudzfz that leads to a file called ge-arctica-pro-sxs-refr-defrost-mode.pdf
#8
Posted 17 July 2011 - 09:16 PM
#9
Posted 17 July 2011 - 09:27 PM
That's from the PSS/GSS service manual. Your box is a PSI-- I don't know that this applies.
Hmm. Interesting. All the test numbers DO seem to do what the chart says they should.
#10
Posted 17 July 2011 - 11:47 PM
Diagnostics
Pages from 31-9118 Artica SxS Dual Evap w Electronic Touch.pdf
- CocoaBeach likes this
#11
Posted 18 July 2011 - 02:34 AM
ahhh similar to 31-9118 w/Custom Cool
Diagnostics
Super helpful -- thank you very much. Actually, note #2 helps a lot -- I did a #15 and a #16 to reset the system, and after doing so, the unit started acting like it used to where opening one of the doors would change how the system operates (something or other would stop running while the door was open and then start running again when the door was closed). And the comment about how the defroster wouldn't come on when the evaporator thermistor is above 70 degrees is also instructive, since when I ran test #14 previously, the coil didn't come on -- something tells me I have a bad evaporator thermistor (and perhaps a bad defrost thermostat).
#12
Posted 18 July 2011 - 02:45 AM
#13
Posted 18 July 2011 - 07:33 AM
... yes, their Jet engines are good ... appliances are another story ...... If they can design and sell a quality jet engine (which apparently they can) they ought to be able to design and sell a quality home appliance. But I digress...
#14
Posted 18 July 2011 - 07:35 AM
And their nuclear reactors, e.g., Fukushima
#15
Posted 22 July 2011 - 01:03 PM
#16
Posted 22 July 2011 - 02:59 PM
The (variable) Thermistor tells the Controller the temperature.
The Defrost Thermostat is just a safety Switch that opens IF the Defrost Heater gets too hot from a Controller failure.
http://www.repaircli...?R=154&N=914093
http://www.repaircli...R=154&N=1170024
#17
Posted 22 July 2011 - 03:58 PM
The new evaporator thermistor arrived and is installed and the defrost cycle now works! MANY thanks for the advice!!!
Let me just add a special thanks because this was a dual-failure problem (thermistor AND motherboard). So if I'd called a technician, it probably would have taken a lot of time (and $$$) to diagnose, if it would have been diagnosed at all (in which case I'd be buying a new fridge (although certainly not a GE) for even bigger bucks).
#18
Posted 22 July 2011 - 04:31 PM
... I'd be buying a new fridge (although certainly not a GE)
