LG DLE5955G dryer door gasket help
2 replies to this topic
#1 spaceboy79
spaceboy79
  • 1 posts
Posted 19 July 2011 - 12:45 PM
So first off I am new, but the Samurai said I could find help ordering and putting this door seal gasket on myself (part 4986EL2004A). It just slowly became loose and came off at the bottom of the inside of the dryer door window and I could not get it back in for anything, then slowly over time the entire seal just came off. I'm ready to call a repairman, It's out of warranty and LG recc. some clown outfit that keeps forgetting to call me back.
Sears Repair has the part, with 8.99 shipping (not available in stores) and isn't available for 1 week. I have serious doubts I can put this part on. Please help if you can.
Thanks, spaceboy
#2 john63
john63
    Dean of LG Appliantology
  • 2,228 posts
Posted 19 July 2011 - 09:11 PM
If the GASKET is not torn---it should be reusable.
This is a fairly simple task.
Remove the *phillips* screws on the HINGE.
Place door on a mat or towel.
Remove the screws from around the perimeter of the door and pry/separate the inner ring.
Reinstall gasket/reassemble.
Having an assistant helps & taking a photo or two with your cellphone camera is a plus too.
To eliminate:
Musty odor
L-O-N-G cycle times
Dingy/yellowing whites
Suds error message
Slow spin speeds
Read below:
HE 2X: (1) Tablespoon
HE 3X: (1) Teaspoon
    Shōgun
  • Master Samurai Tech
  • 31,386 posts
Posted 20 July 2011 - 08:15 AM
And post your photos here! Posted Image
