GEMonogram Mod#ZFSB23DRASS
13 replies to this topic
#1 deezus
deezus
    Kohai
  • Chief Appliantologist
  • 365 posts
Posted 21 July 2011 - 10:27 PM
This refer all of a sudden got hot and stopped cooling. Is there and diagnosis mode to test it? Also, I know how to tell if its the control board but how do I test to see if its the inverter??
Any help would be appreciated!
Ps-everything is running, cond fan, evap fan just not the compressor. If there is power to inverter and comp isn't running would that be an inverter??
Need help.
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 22 July 2011 - 06:52 AM
may be similar to 31-9117
similar, but different MotherBoard
same Compressor
see info starting on PDF page 55
link PM'd
#3 KurtiusInterupptus
KurtiusInterupptus
    B.M.F.
  • 1,916 posts
  • Flavorite Brew:Killians Red
Posted 22 July 2011 - 07:36 AM
120vac to the inverter but no run on compressor...compressor windings check ok? bad inverter.
#4 deezus
deezus
    Kohai
  • 365 posts
Posted 22 July 2011 - 09:21 AM
What ohms am I looking for on compressor? Is that standard for all comp? Where do I check on the inverter board, and does it open?
#5 RegUS_PatOff
  • 33,588 posts
Posted 22 July 2011 - 09:56 AM
PDF page 62
Check compressor for proper resistance.
9 to 11 ohms should be measured between all pins.
#6 deezus
deezus
    Kohai
  • 365 posts
Posted 22 July 2011 - 10:07 AM
Damn, I hope its the board cuz that inverter is expensive!!!
    Shōgun
  • Master Samurai Tech
  • 30,522 posts
Posted 22 July 2011 - 11:10 AM
The actual resistance of the windings don't really matter-- if they're bad, they'll read open. You're simply looking for continuity.
#8 deezus
deezus
    Kohai
  • 365 posts
Posted 22 July 2011 - 11:42 AM
Compressor checks at 11.4 across all pins. Something weird though, when I put it into diagnostic mode, all lights on display go out....3 minutes later they come on!!!! Everything is intermittently running. Sometimes evap fan will run and sometimes it won't, same with compressor. I inspected the board, front and back and saw no visual burn marks.
Test. Gives an f
#9 KurtiusInterupptus
KurtiusInterupptus
    B.M.F.
  • 1,916 posts
Posted 22 July 2011 - 12:39 PM
..Sometimes evap fan will run and sometimes it won't, same with compressor.
You didn't say that before...classic signs of failing LV power supply on mother board...
#10 deezus
deezus
    Kohai
  • 365 posts
Posted 22 July 2011 - 12:54 PM
OK. I was wrong. I took cover off and evap fan comes on and changes speed dependind on door open or closed. I heard a sound coming from inside wall of referand it sounds like something is leaking? If there was an opening in the sealed system would compressor still ohm out?
#11 RegUS_PatOff
  • 33,588 posts
Posted 22 July 2011 - 01:02 PM
... If there was an opening in the sealed system would compressor still ohm out?
yes, and it would usually run but no cooling
#12 deezus
deezus
    Kohai
  • 365 posts
Posted 22 July 2011 - 01:26 PM
That's it there's a leak in sealed system. Sounds like a hole and as comp pumps it hisses.
Ty guys for all your help!!!
#13 KurtiusInterupptus
KurtiusInterupptus
    B.M.F.
  • 1,916 posts
Posted 22 July 2011 - 04:57 PM
So...you have no frost on the evap coil? And the compressor is running steady?
not sure I would say it was a leak unless I tapped the system....if that leak is as large as you think, it wont hold pressure or a vacuum ...
#14 deezus
deezus
    Kohai
  • 365 posts
Posted 22 July 2011 - 05:03 PM
Yea comp is running. It is a leak.
