Fisher and Paykel Oven OD302 OD302M
6 replies to this topic
#1 katehelen
katehelen
  • 10 posts
Posted 27 July 2011 - 12:04 PM
My children were cooking, said that the top oven sparked and then stopped. It works, but it heats up slowly. Early on, while under warranty, the motherboard had to be replaced, or that is what the repairman said, because it heated very, very slowly, like an hour to get to 350. Additionally, when the oven is initially heating up, it is very noisy, but once it is warmed up, it cooks quietly. Finally, the rubber on both of my temperature probes seemed to shrink, and I will replace them, but is this a common problem so that I will be replacing them again and again? Thank you.
#2 kdog
    RoughShod
  • 7,466 posts
Posted 27 July 2011 - 11:33 PM
P/M'd service manual
#3 J5
J5
    Senpai
  • PipPipPipPip
  • 542 posts
Posted 28 July 2011 - 03:46 AM
most likely is the fan forced element has burnt out
unfort you do need to remove the oven to change the element as the wires are not long enough to do it from the inside of the oven
#4 katehelen
katehelen
  • 10 posts
Posted 28 July 2011 - 10:48 PM
I saw the repair guy remove my oven once before, he had something that he had made that the oven sat on while it was being worked on. I think I could probably make a box like that then pull the oven out and put it on it. Thanks for the information.
#5 J5
J5
    Senpai
  • PipPipPipPip
  • 542 posts
Posted 29 July 2011 - 02:14 AM
i usually use milk crates
the cable is usually long enough to pull it out and sit it down
remove the door and racks as there is about 20 kg in that stuff
#6 katehelen
katehelen
  • 10 posts
Posted 21 January 2012 - 02:59 PM
Replaced the fan element in the oven (yes, I know it has taken several months to get around to it). Now the element is on full time and will not shut off when I shut off the oven. (BTW, you hit the nail on the head with the idea that it was the fan element that busted. It had a hole in it when I finally pulled it out. We are reading the manual right now, but thought I would ask you if I did something obvious wrong.
#7 appl.tech.29501
appl.tech.29501
  • 8,027 posts
Posted 21 January 2012 - 05:15 PM
sounds like the element is partially shorted to ground...or either you have a bad controller. first check to ensure that the element is installed correctly and not touching anything it shouldn't.
