Sealed system equipment
#1
Posted 03 August 2011 - 09:20 PM
#2
Posted 14 August 2011 - 10:37 AM
#3
Posted 04 September 2011 - 12:25 AM
#4
Posted 04 September 2011 - 12:45 AM
#5
Posted 06 September 2011 - 12:22 AM
I was/am afraid to get into doing domestic sealed system work. Mainly because of the high cost of the equipment, EPA regs, and the high probability of getting a call back.
Have call backs been a problem, or is this an urban myth?
#6
Posted 11 October 2011 - 12:25 AM
#7
Posted 12 October 2011 - 09:09 PM
Dylan, I'm sure you do a good job with sealed system work.
No reason to get a call back if the jobs done properly. As with any repair most call backs are due to
the technician getting in a hurry and not checking behind themselves (assuming they do know
what their doing ) . However you will hardly ever do sealed system work on most standard refrigeration
(unless you do warranty work).
You may get a Sub Zero or other high end built- in occassionally.
You also have to be very careful. Most of the units that are worth a sealed system repair are in
very nice homes. The units most often have custom panels and nice flooring that can easily get
burned with a torch or damaged by all the equipment you have to lug in.
- RussTech likes this
www.eliteapplianceservice.org
