Frigidaire Model #PLEB3089DCB
4 replies to this topic
#1 texasrookie
texasrookie
  • 12 posts
Posted 10 August 2011 - 11:51 AM
Hi, I have a Frigidaire oven that was working fine, until I used to clean function and now the elements don't heat. I did spray oven cleaner prior to starting the oven clean function. Where do I go from here?
#2 kdog
    RoughShod
  • Senior Appliantology Fellow
  • 7,474 posts
Posted 10 August 2011 - 01:32 PM
Might have tripped the limit switch during the CLEAN cycle (usually means clean your wallet out in resulting service calls to get it running again), but I'll let Reg explain that - The cutout should be located somewhere at the rear under the cover panel and looks like the one pictured below:
http://www.repaircli...ber=PLEB30S9DCB
#3 DurhamAppliance
    Sho' Nuff Chozin
  • 6,071 posts
Posted 10 August 2011 - 01:47 PM
ODE TO A CLEAN CYCLE
How do I love thee?
Let me count my money.
:wub:
Edited by DurhamAppliance, 10 August 2011 - 01:49 PM.
www.DurhamApplianceThrift.com
#4 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 10 August 2011 - 01:51 PM
My eyesight isn't as good as it once was (see RegUS_PatOff )
but from here it looks like your model number may be
PLEB30S9DCB
... the CLEAN cycle (usually means clean your wallet out in resulting service calls to get it running again),
“My Rules”:
Rule # 1) Don't ever use Self-Clean on any Oven.
Rule # 2) If you're thinking about using Self-Clean, see rule # 1.
Self-Clean uses nearly 1000F for 3 hours or more. Posted Image
That can wreak havoc on Electronic Controllers and Connections.
#5 kdog
    RoughShod
  • 7,474 posts
Posted 10 August 2011 - 01:53 PM
Awww - you forgot my favorite part : :nono: and :boohoo:
