Whirlpool Duet Elect dryer WED9200SQ1
5 replies to this topic
#1 cmwyatt
cmwyatt
  • 2 posts
  • Flavorite Brew:Shiner Bock
Posted 15 August 2011 - 11:50 AM
Our Duet dryer is overheating the clothes even after the cool down cycle has completed, the clothes come out super hot, I cleaned and inspected the blower assm. removed vent hose and it is clear, no obstruction, also the wall duct is clear.. still the dryer seems to be in good operating condition.. i.e. everything works as normal..no codes, no shut down etc. I've researched this and found little help.. is there some type of thermo switch or thermostat etc.. thanks for any help.. By the way, Self employed specialized cleaning equipment tech... Floor machines etc..
#2 KurtiusInterupptus
KurtiusInterupptus
    B.M.F.
  • 1,960 posts
  • Flavorite Brew:Killians Red
Posted 15 August 2011 - 12:21 PM
You need to inspect the heat element to see if it has broken and welded itself to the can...this will cause constant heating...prolly will blow the thermal fuse or high limit if this continues...
#3 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 15 August 2011 - 12:41 PM
try running a load with the Vent disconnected ..
Dryer Vent
Vent should be rigid metal.
NO plastic
NO PVC
NO screws
Foil Duct Tape is OK.
Check / clean the Dryer Vent
#4 cmwyatt
cmwyatt
  • 2 posts
Posted 15 August 2011 - 01:18 PM
Kurt... I'll look into that ...
RegUS... everything you listed is in order..meaning already checked those issues, using foil vent hose..no kinks etc. 100% clear.. no blockge.. air flow duct in wall is clear no blockage... air flow coming out off wall on outside is normal, good flow... This dryer has been unchanged, not moved bumped etc. since installed 3yrs ago, this issue just began last week.. but i'll recheck everything again.. thanks for the info guys
#5 kdog
    RoughShod
  • Senior Appliantology Fellow
  • 7,474 posts
Posted 15 August 2011 - 01:26 PM
May be some information of interest in this example : http://appliantology...uet-gew9200lw0/
#6 RegUS_PatOff
  • 33,588 posts
Posted 15 August 2011 - 01:44 PM
... try running a load with the Vent disconnected ..
... With an empty load, Timed Dry, High Heat, the vent temperature should cycle somewhere between 135F and 160F
