Sign in to follow this
Followers 0
doogdoog
Whirlpool Washer LA5800XSNO Tub Removal
17 posts in this topic
Aloha,
I have a Whirlpool LA5800XSNO that looks like it is leaking from the bottom of the tub. I want to remove the basket and tub so I can see if the tub is cracked or maybe a seal? How do I remove the tub?
Best bet is to locate leak with as little disassembly possible so that you can first verify it
On Whirlpool/Kenmore direct drive washers, the pump is down in front and you’ll need to remove the cabinet to check it out
We use the 7th and 10th law of the prophecy here : http://fixitnow.com/wp/2005/09/23/samurais-12-laws-of-appliance-repair/
Aloha Kdog,
Thanks for the reply and I did remove the cabinet and filled some water in the tub and it looks like the water is dripping from around the area (bottom of the tub) where the shaft goes up into the drum. I can't really see up there because of the brackets, etc. I was thinking that if I could remove the tub, I could check it out and see if there is a crack or seal that it is leaking from. Do I remove the basket, nut on shaft, and pry off the ring on top of the tub?
Aloha,
I removed the basket and want to know if the tub can be removed from the shaft that turns the agitator. It is leaking from the tub where there looks like a rubber seal at the bottom of the tub. Is the shaft in the tub considered as one piece and cannot be removed? Is the threaded portion on the shaft where the spanner nut is removable? I will try to post some pictures.
post-13179-0-17231900-1313558715_thumb.j
post-13179-0-07319500-1313558731_thumb.j
Edited by doogdoog
Merged Threads
Aloha Kdog,
Thanks for the video Kdog, that told the whole story. I'll finish the removal of the tub and I will order the parts from your site. Oh, do you also sell the spanner wrench that was shown on the video (that is a must have)?
Edited by doogdoog
That tub seal isn't going to be of any help if there is an actual hole rusted through the support tube!!!!
If what you have pointed out in the picture just above the tub seal is an actual hole you will have to have it welded up and then smoothed out so the new tub seal can slide down past the welded spot or replace the complete super structure support assembly that includes new bearings and seals.
I really wouldn't try the route of welding the hole because if water has been inside the support tube and is running out the tube at the bottom then that means the bearings and seals have been destroyed from the water also.
A new super structure support assembly is probably going to be around $100-$150.
Aloha Willie,
Yes, that is a small hole in the tube and I didn't have time to do any work on it today so I don't know how much damage was done. I will pull the tub (hopefully tomorrow) and see how bad everything is. Do they sell that tube (what is it called?)? I just discovered that there is water sloshing around in the rim that is on top of the basket. Is that water or is it made that way? If it is water, how did it get in there and how do I remove it? Will it cause an unbalanced spin condition?
Thanks Kdog, and what does the sodium chloride do? I read somewhere that somebody thought that was water in there and drilled a small hole to empty it out because he was having balance problems. Thanks for telling me or I probably would have done the same thing. LOL Thanks again.
Mahalo,
doogdoog
... and what does the sodium chloride do?
it's a liquid balance ring ..
doesn't freeze, etc ..
Today I removed the tub and there isn't a hole where I thought it was. It looks like the bottom part of the tube started to rust up into the seal (or from the top of the seal down) and caused the water to leak. I guess the rust puffed up under the seal, so some water passed. I posted a picture and was wondering if the seal sits flat on the housing itself or about 1/4"-3/8" above it. There seems to be a 1/16" raised surface on the tube so I included a picture.
post-13179-0-21040000-1313646108_thumb.j
Wow, there's a leak that didn't just start yesterday - the seal is made on the tube above the collar, in the area that is clean on the tube. You migt get away with a new seal if you clean the rust off carefully with some fine sandpaper and some acetone
Aloha Kdog,
It must have been seeping for quite a while until it got worse and that is when I noticed the concrete looked a little wet. I am going to clean it up to see if a new seal would work and see if any welding is required. I love this old washer because it doesn't have any high tech electronics involved and is easily repaired by a DIY person (the hard part is how to get that blasted tub out). LOL Thanks again.
Followers 0
