LG washer
8 replies to this topic
#1 swenson
swenson
    Sōhei
  • 178 posts
Posted 17 August 2011 - 01:59 PM
Pump is shot keeps getting stuck and pump turns on when its in speed wash or normal only when its spinning early in the cycle when it spins clockwise then counter clockwise is when pump turns on only when spinning had in diagnostics is turns on in that. Does not seem rt to me is it suppose to pump water when its agitating? what can cause this to happen
#2 swenson
swenson
    Sōhei
  • 178 posts
Posted 17 August 2011 - 02:04 PM
WM3001HA model# it also has fe error code which did not happen when I filled machine in cold and hot
#3 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 17 August 2011 - 03:26 PM
... also has fe error code
FE OVER FLOW ERROR
• Water is overflowing (water level frequency is over 213).
FE If is displayed, the drain pump will operate to drain the water automatically.
#4 kdog
    RoughShod
  • Senior Appliantology Fellow
  • 7,474 posts
Posted 17 August 2011 - 07:14 PM
Unit has 2 pumps no ?? One recirculates during tumbling, the other drains tub
http://www.repaircli...ER1001A/1267020
http://www.repaircli...EA2002H/1461702
http://www.repaircli...EA2001D/1266821
#5 swenson
swenson
    Sōhei
  • 178 posts
Posted 17 August 2011 - 08:47 PM
yup 2 motors the one on the left is getting stuck and is on when trying to drain and is on when unit is tumbling
#6 RegUS_PatOff
  • 33,588 posts
Posted 17 August 2011 - 10:49 PM
did you check the Water Level and Frequency ?
#7 swenson
swenson
    Sōhei
  • 178 posts
Posted 19 August 2011 - 02:48 PM
yes i did check freq ,water level below the metal part of tumbler was not near the door and compared to other lg's ive worked on looked a normal level for water. It seems to happen just when in to the rinse cycle or just before the rinse cycle. I ran the washer in cold first no fe error then hot fe error as soon as it stopped filling i shut off washer.
#8 RegUS_PatOff
  • 33,588 posts
Posted 19 August 2011 - 04:54 PM
...so... what is the Water Level Frequency when it fails ?
#9 swenson
swenson
    Sōhei
  • 178 posts
Posted 23 August 2011 - 12:32 PM
It did not fail I take it the best time to check water freq is right when it displays the error code? How long do you wait until the water freq. test is done?
