GE,gas range, JGSP30GER3
7 replies to this topic
#1 swenson
swenson
    Sōhei
  • 178 posts
Posted 17 August 2011 - 02:07 PM
complaint is tempature is way offoven heats just does not stay at what the tempature is set too what can cause this?
#2 kdog
    RoughShod
  • Senior Appliantology Fellow
  • 7,474 posts
Posted 17 August 2011 - 06:55 PM
http://www.repaircli...er=JGSP30GER3BG
#3 swenson
swenson
    Sōhei
  • 178 posts
Posted 17 August 2011 - 08:45 PM
what about the tempature sensor?
#4 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 17 August 2011 - 10:46 PM
... how far "off"
actual temperature is higher or lower than set temperature ?
#5 kdog
    RoughShod
  • 7,474 posts
Posted 17 August 2011 - 11:42 PM
The Heat fluctuation is due to delayed ignition, almost guarantee that ignitor is failing - toss a clamp on it
#6 swenson
swenson
    Sōhei
  • 178 posts
Posted 19 August 2011 - 03:53 PM
its off by alot 350 set temp thermometer reads 250 when oven is set to 400 deg thermometer reads 400 deg.
#7 RegUS_PatOff
  • 33,588 posts
Posted 19 August 2011 - 05:19 PM
could be a bad Temperature Sensor
OR Controller
http://www.repaircli...?R=154&N=254363
Temperature Sensors
1100 @ 75° F (23.8° C).
http://www.repaircli...?R=154&N=252618
OR this would work, but you would need a pair of ceramic wire nuts
http://www.repaircli...?R=154&N=911009
#8 kdog
    RoughShod
  • 7,474 posts
Posted 19 August 2011 - 05:31 PM
Sounds like alot of down time between heat cycles, did you happen tho check current draw of ignitor ??
