Maytag MFF2558KRW french doors, bottom freezer
4 replies to this topic
#1 waikoloa appliance
waikoloa appliance
  • 4 posts
Posted 17 August 2011 - 04:02 PM
Is there a sequence to manually put this freezer into defrost mode? The wiring diagram does not show a defrost timer and the heater and defrost terminator wires go into the jazz pc board. I suspect the defrost terminator to be the problem but would like to confirm before I start snipping wires.
Sorry model # is MFF2558KEW
#2 waikoloa appliance
waikoloa appliance
  • 4 posts
Posted 17 August 2011 - 04:14 PM
What is an adaptive defrost in newer models, which replaces the defrost timer?
#3 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 17 August 2011 - 05:07 PM
one of the functions of the Jazz Board
Defrost Operation:
The Control Board adapts the compressor run time between defrosts to achieve optimum defrost intervals
Enter the Forced Defrost Mode by performing the following sequence of events:
1. Hold the refrigerator door light switch closed.
2. Press the Refrigerator Temperature Down keypad 3 times consecutively within 10 seconds.
#4 graham1234
graham1234
  • 10 posts
  • Flavorite Brew:BUD LIGHT
Posted 28 August 2011 - 04:47 AM
What if the diplay is not working?
    Shōgun
  • Master Samurai Tech
  • 30,389 posts
Posted 28 August 2011 - 10:01 PM
Are you saying the display isn't working? If that's the case, then you need to verify valid power supply to both the refrigerator and to the display board. Tech sheet and wiring diagram and located behind the toe grill down in front.
How to enter forced defrost mode in a Maytag refrigerator with the "Jazz" control board
By Samurai Appliance Repair Man in Samurai Appliance Repair Man's Blog, on 19 August 2011 - 08:44 AM
ame='RegUS_PatOff' date='17 August 2011 - 06:07 PM' timestamp='1313618820' post='205756']
one of the functions of the Jazz...
Read Full Entry →
