Affinity Washer E41 Error Code
6 replies to this topic
#1 Aedsb
Aedsb
  • 3 posts
Posted 20 August 2011 - 07:41 PM
I have a Frigidaire Affinity washer (LAFW3511KW0) that is giving an E41 code. I have unplugged the washer (no change), checked the stricker (fine), and I have unplugged the three connections to the latch assembly. I received an E41 when the latch assembly was disconnected. When reconnected, I still received the same error code. How can I further troubleshoot this problem to determine if the problem is the latch assembly or the circuit board?
#2 RegUS_PatOff
  • 30,192 posts
Posted 20 August 2011 - 08:06 PM
when the Washer is in the Spin Cycle, and the Door is locked...
is it really locked ?
Then unplug the Washer's Power Cord from the Wall Outlet.
Can you then open the Door right away,
or only after a few minutes ?
#3 Aedsb
Aedsb
  • 3 posts
Posted 20 August 2011 - 08:24 PM
The door will not lock and it will not start any cycles. When I try to start a cycle, the machine immediately pauses.
#4 kdog
    RoughShod
  • 7,428 posts
Posted 20 August 2011 - 08:37 PM
http://www.repaircli...ber=LAFW3511KW0
#5 Aedsb
Aedsb
  • 3 posts
Posted 20 August 2011 - 09:03 PM
How do I know that I need the latch assembly instead of the circuit board?
#6 RegUS_PatOff
  • 30,192 posts
Posted 20 August 2011 - 09:15 PM
#7 kdog
    RoughShod
  • 7,428 posts
Posted 21 August 2011 - 12:24 AM
Look here: http://fixitnow.com/...e43-error-code/
