mitch3gp
Changing Hot water shutoff valve-Can't get rear panel off-Kenmore
7 posts in this topic
Sensei,
Looking for guidence on removing rear panel to replce Water Mixing valve.  Thanks,
Grasshoppah
:yikes: DO NOT REMOVE THE REAR PANEL!!!!!! Post a model number (should be 110. followed by 8 digits) so we can see what you actually have, the process varies depending on which vintage of Kenmore you have.
Here is the model number 110.23822100
Kenmore washing machine bought Nov. 2002
Thanks!
Mastah,
I am but a grasshoppah, learning the ways of Applinatology.
During the fill cycle the tub over flows into the washer drip pan/tray.  (the washer is on the third floor).  Troubleshooting has resulted in buying a new water mixing vlave.  Is this the right course?
Should I have considered:
1   Water vlave
2   Water level switch
3   Rubber hose going to water level switch
2 and 3 are your first ports of call. The hose can get pinched, I have even seen some of these where the hose runs through a little retainer on the side of the tub - the hose rubs on this and eventually wears through.
Changed out the water mixing valve cause I had it.
Checked out the pressure tube.  Looked ok.
Ran one test cycle-checked good.
If problem persists I'll change the tube and water switch.
Thanks.  Good info.  Good times!
