Sign in to follow this
Followers 0
eveready service
kenmore chest freezer 253.16922105
3 posts in this topic
Hi Guy's,
I don't work on refers or freezers but my friend got water in his bsmt. Sears came out & said too much to fix so I looked at it and can see the overload is trashed. The run cap is sealed so I think its OK. The thermo looks OK and isn't the compressor sealed so that the water shouldn't have bothered it. The overload is only 25.00, and I think it's worth a shot. I would appreciate any input on this repair as they can't afford a new one right now.
Overload & PTC Starter .. ?
Could try Compressor test cord ..
Probably a start relay failure. Will the freezer run after being unplugged for a while? IF so, unplug and immediately plug it back in. If it doesn't run then something is going on with the start cycle. Could be start relay, could be compressor start windings. You can try the following before spending money on a start relay:
Water may not have gotten in the compressor but it could have caused a short across the compressor pins resulting in electrical damage to the compressor. You can test for electrical damage to the start and run windings by testing the three pins on the compressor. Your pin configuration should be one on the top and two on the bottom or reverse. The solo pin should be your common (not always, but i think true in your case). The other two should be run and start. Measure ohms from common to one of the pins, record the value and then do the same for the other. The pin that reads the highest ohms when measured with common is the start (label that reading "S") and the other is the run ("R") . Now measure readings from start pin to run pin. Record that number ("X"). You should get S+R=x. If more than .5 ohms off, then you got an electrical problem inside the compressor. Also do a continuity test from each pin to the body of the compressor to rule out a short. If your compressor fails either test then trash the fridge as being too expensive to repair. If it passes then you can try a test cord (you need to remember the location of start, run and common pins) to check for mechanical problems.
Edited by DurhamAppliance
Followers 0
