Maytag, washer,MVWB700Vq0
5 replies to this topic
#1 swenson
swenson
    Sōhei
  • 178 posts
Posted 23 August 2011 - 12:11 PM
Complaint is it has a LF error code and the soil light and wash light were not lit I looked at the washer and those lights are working now what should be replaced on this. How do you change out the water valve on a maytag bravos quiet series?
    Shōgun
  • Master Samurai Tech
  • 31,387 posts
Posted 23 August 2011 - 12:56 PM
That's a long fill error. Does the tub fill at a reasonable rate? Are both the hot and cold water flow normal?
#3 swenson
swenson
    Sōhei
  • 178 posts
Posted 24 August 2011 - 10:48 AM
no cold water only hot valve appears to be opening sometimes what would cause the lights both soil and wash to not light do they not light when there is a error?
    Shōgun
  • 31,387 posts
Posted 25 August 2011 - 08:49 AM
Rinse is done with cold water. If that valve is plugged, it'll throw an LF code during rinse. Replace the water inlet valve ==> Water Inlet Valve
Service manual PMed.
EDIT: couldn't PM the manual because your Apprenticeship expired!
Edited by Samurai Appliance Repair Man, 25 August 2011 - 08:50 AM.
#5 kdog
    RoughShod
  • Senior Appliantology Fellow
  • 7,474 posts
Posted 26 August 2011 - 12:27 AM
Wow - you got your 10 bucks worth !
    Shōgun
  • 31,387 posts
Posted 26 August 2011 - 12:50 AM
Hello, Newman!
