Maytag Centennial Electric Dryer Model #MEDC400VW
18 replies to this topic
#1 SANTA
SANTA
    Senpai
  • PipPipPipPip
  • 818 posts
Posted 30 August 2011 - 11:20 PM
I'm not an electrician but I installed a new dryer for my sister the other day. This is an older house and the dryer outlet was a 3 wire electric range type. The new dryer cord is a 4 wire type so I changed the outlet to match the cord. Everything on the dryer works except the interior light. I only get 50 volts. Please mister wizard, tell me what I did wrong or do I have a problem with the dryer itself.
#2 SANTA
SANTA
    Senpai
  • PipPipPipPip
  • 818 posts
sorry, don't know how I double posted.
Edited by SANTA, 30 August 2011 - 11:22 PM.
#3 kdog
    RoughShod
  • 7,466 posts
Posted 30 August 2011 - 11:24 PM
Topics merged
Unfamiliar with the 3 wire set-up (that's illegal here), do you join the Neutral and ground together?
#4 kdog
    RoughShod
  • 7,466 posts
Posted 30 August 2011 - 11:29 PM
Wouldn't you be better off to change the receptacle to a 4 wire instead of replacing the whole cord ?
#5 SANTA
SANTA
    Senpai
  • PipPipPipPip
  • 818 posts
Posted 30 August 2011 - 11:34 PM
Thats what I did. The house wire is only 3 wires, black, red, white.
#6 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 30 August 2011 - 11:35 PM
... I changed the outlet to match the cord.
... should check local codes, may require a 4-wire Dryer Outlet & Cord
Also would need to change the Fuse / Breakers from 50A to 30A
On the 4-wire Outlet, the top-center is Neutral and the bottom-center is ground.
Left and right are "hots"
On the 3-wire Outlet, the center is Neutral
and Left and Right are "hots"
Check the voltages at the Outlet
#7 kdog
    RoughShod
  • 7,466 posts
Posted 30 August 2011 - 11:36 PM
So it depends on the Neutral wire to ground it, wouldn't you also need to Ground the cabinet to Neutral ?
#8 RegUS_PatOff
  • 33,588 posts
Posted 30 August 2011 - 11:39 PM
if it uses a 3-wire Cord,
the "center" Neutral Terminal on the Dryer, and the "chassis" are tied together
#9 kdog
    RoughShod
  • 7,466 posts
Posted 30 August 2011 - 11:43 PM
I'm not an electrician .
Me neither (far from it), but I have never seen this in practice so I guess we are all learning
#10 kdog
    RoughShod
  • 7,466 posts
Posted 30 August 2011 - 11:46 PM
You could try and measure voltage between hot wire of lamp socket and powercord neutral to see if you have full voltage there
#11 SANTA
SANTA
    Senpai
  • PipPipPipPip
  • 818 posts
Posted 30 August 2011 - 11:58 PM
The voltage from the outlet and to the dryer are ok. I'm sure the old 3 wire outlet isn't up to code. If it's a safety issue maybe I should have her hire an electrician to make it right.
Edited by SANTA, 30 August 2011 - 11:59 PM.
#12 RegUS_PatOff
  • 33,588 posts
Posted 31 August 2011 - 12:01 AM
... and there's 120v from each "outside" Terminal to "center" Terminal, on the Dryer ?
#13 SANTA
SANTA
    Senpai
  • PipPipPipPip
  • 818 posts
Posted 31 August 2011 - 12:04 AM
Yes sir there is.
#14 RegUS_PatOff
  • 33,588 posts
Posted 31 August 2011 - 12:07 AM
Yes sir there is.
... while Dryer is running ?
#15 SANTA
SANTA
    Senpai
  • PipPipPipPip
  • 818 posts
Posted 31 August 2011 - 12:12 AM
I'll have to check that later but after rehashing my voltage testing in my mind I remember getting 100 volts from each hot wire to the ground on the new outlet and thinking that was kind of odd because there's no ground wire.
Edited by SANTA, 31 August 2011 - 12:23 AM.
#16 kdog
    RoughShod
  • 7,466 posts
Posted 31 August 2011 - 12:24 AM
P/M'd you the service info - check section 2-4 regarding the cord
#17 SANTA
SANTA
    Senpai
  • PipPipPipPip
  • 818 posts
Posted 31 August 2011 - 12:33 AM
Thanks, I'll have to look at it in the morning. I need my beauty sleep.:scotsgit:
#18 nickfixit
nickfixit
  • 2,195 posts
  • Flavorite Brew:Glen Livit
Posted 31 August 2011 - 05:29 AM
If you changed the recepticle to a 4 wire, you would need to have added a ground wire to make it work right. If the dryer is properly connected as a 4 wire, then the receptice must have the neutral and the ground seperate from each other and the ground must actually be a good working ground. Also, on the dryer the neutral and the ground must be separated.
On a 3 wire setup, the recepticle has 2 120volt lines that are out of phase with each outer and a common neutral. The dryer will have the neutral and ground connected together.
I deal with a lot of this stuff.
Nick
#19 SANTA
SANTA
    Senpai
  • PipPipPipPip
  • 818 posts
Posted 31 August 2011 - 04:33 PM
Thanks Nick. I think it would be wise to have an electrician rewire the outlet if there's a possibility of it being unsafe.
