Maytag Neptun MDG3000AWW
maytag neptun cold air not drying
4 replies to this topic
#1 medrison
medrison
  • 2 posts
Posted 31 August 2011 - 08:35 PM
My dryer is blowing only cold air, so I opened the front cover and did some testing and measurements. When I turn the machine on, it rolls and the igniter gets really bright but no flame or fire on the burner, and then after a few seconds the igniter turns OFF. I removed both solenoids and they measure - the big one 650 ohms and the small one 1.3 kohms - kind of OK. I measure the voltage at the solenoids plugs. After I turn ON the machine, the big solenoid gets 120V untill the igniter turns OFF when the small solenoid gets 120V. I installed them back and checked the sensors. Both measure 0 ohms conductivity. Still the burned does not start. I checked the panel settings, the outside gas valve, all OK.
What else can be wrong?
Thank you,
Mike
#2 kdog
    RoughShod
  • 7,428 posts
Posted 31 August 2011 - 08:49 PM
The coil that has 3 connections is actually 2 coils in one housing, the center terminal is common - one is likely open (booster coil)
http://www.repaircli...mber=MDG3000AWW
#3 medrison
medrison
  • 2 posts
Posted 01 September 2011 - 11:34 AM
Ohhh...really....then that's the problem...cause it does not measure anything in between the side pins and the middle one...just between the sides pins.
Now I looked online to buy a new one, and found some that the seller does not list as compatible for my dryer although it looks the same. Are they all the same or do they have different resistance value so I should look only for the ones for my specific dryer?
Thank you,
Mike
#4 kdog
    RoughShod
  • 7,428 posts
Posted 01 September 2011 - 02:23 PM
#5 nickfixit
nickfixit
  • 1,965 posts
Posted 02 September 2011 - 04:19 PM
Whirlpool part number 289374, the identical part used on many other brands.
Also tagged with one or more of these keywords: maytag, neptun, cold air, not drying
