Whirlpool Estate taws800jq0 only works on spin cycle
8 replies to this topic
#1 hmm
hmm
  • 4 posts
  • Flavorite Brew:those shared with friends
Posted 04 September 2011 - 10:16 AM
Please help! A friend's 11 year old Whirlpool Estate washer will only function in the "spin" cycles. Previously, the machine worked fine and when a new load was tried...nothing but spin. We have checked the water flow and the filter screens which are all fine. There is power and the lid switch was recently replaced and again, it will function in spin.
I checked the water level switch tube for clogging and could not find any. I also tested that switch for resistance and got a reading of zero ohms.
I next checked the inlet valve for resistance and got a reading of 1,150 plus ohms (some slight fluctuation but 1,150 minimum). This seems to be outside the acceptable spec. Would this cause all of the other functions to cease? If so, is there a way to "trick" the washer into thinking it is full of water to verify that the other functions will work so that I can make sure it is not the water level switch or the timer? Where do I go from here?
Help! The laundry is getting mountainous!
#2 RegUS_PatOff
  • 30,689 posts
Posted 04 September 2011 - 12:32 PM
... I checked the water level switch tube for clogging and could not find any. I also tested that switch for resistance and got a reading of zero ohms.
Should be 0 ohms across Violet to Tan when the Washer is full.
Does the Washer Motor make any noise during Agitate ?
#3 hmm
hmm
  • 4 posts
Posted 05 September 2011 - 11:29 AM
I tested across violet to tan but the instructions I had stated to do this with the washer empty. The washer was empty because it had gone through all of it's cycles on the previous use. The washer does nothing and makes no noise except on spin. No buzzing or humming or any other perceptible noises. On spin, the drum seems to rotate fine.
#4 RegUS_PatOff
  • 30,689 posts
Posted 05 September 2011 - 12:06 PM
Should be 0 ohms across Violet to Pink when the Washer is empty
#5 hmm
hmm
  • 4 posts
Posted 05 September 2011 - 12:17 PM
I tested across violet to tan AND violet to pink but with the washer empty for both. I seemed to get zero ohms both ways empty. What would that mean?
#6 RegUS_PatOff
  • 30,689 posts
Posted 05 September 2011 - 12:38 PM
that would mean it's bad, although it should then Agitate OK...
(if you're using your OHM meter correctly)
#7 hmm
hmm
  • 4 posts
Posted 05 September 2011 - 01:07 PM
Would it agitate if the switch were bad? I was under the impression that the agitation only started when the switch sensed that the tub was full of water. Is there a way to bypass or trick the switch into sensing a full tub of water?
Thanks for your help!
#8 RegUS_PatOff
  • 30,689 posts
Posted 05 September 2011 - 01:43 PM
It will only Agitate when the Switch contacts Violet & Tan are connected = 0 OHMs
  • 24,698 posts
Posted 06 September 2011 - 11:56 AM
Part link ==> Pressure Switch
