Medium Speed "sputtering" in Whirlpool GSX9885JQ0
Motor
25 replies to this topic
#21 RegUS_PatOff
  • 30,708 posts
Posted 07 September 2011 - 07:02 PM
should be using a digital OHM meter on the 200 OHM scale
#22 jgarb
jgarb
  • 13 posts
  • Flavorite Brew:Shakeology
Posted 07 September 2011 - 09:33 PM
So with out the meter I can not seem to help the situation. my scale read just past the 1 ohm mark. I thought it telling that the Resistance test between P9-2 and P7-2 was zero. I expected a value.
#23 Moostafa
Moostafa
    Senpai
  • The Ayatollah of Appliantology
  • PipPipPipPip
  • 765 posts
  • Flavorite Brew:Poppy Salmagundi
Posted 07 September 2011 - 10:04 PM
Hello, my expectant friend. Our tumescent and flatulent host has prepared a tome on the subject of making basic electrical measurements which may provide some illumination, however meager, in your resistance measurement challenges. Would you like to see it? Alright, it is here... http://fixitnow.com/...l-measurements/
Allahu Akbar!
#24 jgarb
jgarb
  • 13 posts
Posted 17 September 2011 - 07:44 PM
Okay - I "rounded-up" a real Ohm Meter. and the digital readings are attached. There seemed to be no reading at all between P9-2 and other wires. I decided to pull the case and check out the connections at the motor, where I found a broken wire at a (two-wire clip Connection). See Attached pictures.
#25 RegUS_PatOff
  • 30,708 posts
Posted 17 September 2011 - 07:52 PM
:thumbsup:
#26 Samurai Appliance Repair Man
  • 24,721 posts
Posted 17 September 2011 - 07:56 PM
Nice shootin', Hoss! :armed:
Also tagged with one or more of these keywords: Motor
